Connect hp 4580 to asus ME302C
How to connect (print)
1 Related Answer
Donna Sander
  • 277 Answers
  • Posted on Jan 13, 2010
SOURCE: the print job in the print queue is preventing
If one job isn't printing, cancel it, and let the other one's print. I read somewhere there is a 2GB limit on print spool jobs...and if you reach that limit, everything locks up. I am not sure on it...but if you have a realy large document, either print it alone, well, just print it alone. Try to spool your print jobs from the smallest ones first, and don't overload it. The is especially true of printing pictures...because if you don't resize them, they can be especially large files (and large pictures) sometimes you don't realize that what you are viewing on screen is only 26% of the actual picture size...especially if you have say, a 8MP or higher camera pixel size capability.
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Will installation of a asus miracast dongle allow me broadcast from my asus s400ca to my LG TV wirelesslyasus asus support
ASUS Miracast Dongle lets you experience Full HD wireless entertainment and lets you stream your favorite movies, videos and photos through to any compatible large screen TV. Easy to set up and play, Miracast Dongle supports dual-band wireless (2.4GHz and 5GHz) and HDMI to ensure no latency in signal transmission.
  • Compatible Model ASUS MeMO Pad HD 7/ME173X
    ASUS MeMO Pad FHD 10/ME302C
    ASUS MeMO Pad FHD 10 LTE/ME302KL
    Nexus 7 (2013)/ME571K/KL
    ASUS Transformer Pad/TF701T TF103C
    ASUS Fonepad 7 /ME372CG
    ASUS MeMO Pad 10/ME102A
    ASUS MeMO Pad 8/ME180A ME181C ME181CX
    ASUS MeMo Pad 7/ME170C ME176C ME176CX
    ASUS Fonepad Note6/ME560CG
    ASUS FonePad 7/FE170CG
    ASUS FonePad Pad 7 Dual SIM/ME175CG
    ASUS The new Padfone Infinity/A86
    ASUS VivoTab Note8/M80TA
    ASUS Transformer Book/T100
    ZenFone/A400CG A450CG A500CG A501CG A500KL A600CG
    PadFone mini/PF400CG
    Padfone S/PF500KL
ASUS Miracast Dongle Specifications
Ii need a simple operating manual for a new asus tablet model number me302c
http://www.central-manuals.com/downloads/downloads_tablets/asus/MeMO_Pad_FHD_10_e8319_ME302C_en.pdf
Hp 4580 won't scan. prints & copies ok
1. did you install the software to the computer?
2. what is the OS of the computer?
3. how is the printer connected to the computer?
4. are you trying to scan from the printer or from the computer?
5. are you getting an error messages when you tried to scan?
Users Manual for HP 4580 All-in-one Printer. How
Please download the user manual from this link
static.tigerdirect.com/pdf/HP-Officejet-J4580-Printer-Manual.pdf
Hope this information will help you
thank you
3helpful
3answers
Problem of incompatible cartridge occure in my new J 4580
i had the same problem with the hp 4580. i needed to replace the black ink which i did. then the error message appeared "incompatible print cartridge tri color"...chatted with hp customer support, wasted a hour. claimed its a hardware problem need to have it fixed. i asked would i be charge he said yes but the printer was under warranty. he asked other questions...bottom line i left the chat box....bought another hp 4580, used same cartridges, same message...THEN finally i replaced the color cartridge...and BAM! it worked on both printers. solution...replace the color cartridge...cons..if this happens again its a waste of money to keep buying the colored ink...
2answers
Incompatible cartridge error in j 4580
refix your cartidge .may be your cartridge is faulty.
k24674
Grand Canyon Tech
Grand Canyon Tech
