Temp Is high in both food and freezer Error code ICE E3
Hello friend, thanks for your inquiry!
Based off the information you provided if your refrigerator is displaying an "E3" error code you could be seeing a problem within the main control board or thermistor. I would suggest a reset to your appliance, this can clear any false codes, and you can do this by unplugging your appliance for roughly ten minutes. I hope this is helpful. -Matt
SOURCE: Items sometimes freeze on refrigerator side of unit - model GSS25LGMA
It is most likely a bad damper motor. This is where the cool air comes out into the fridge section. On this model it is a fairly common problem and comes a whole assembly. The part # is WR49X10091 and will cost anywhere from $100 to $122. Knowing this model I would bet this is your problem. If the damper is bad and stuck open cold air will just keep blowing in. It is suppose to open and close based on the temp setting. Let me know if you have any other questions.
SOURCE: Kenmore Elite Trio Model 795.7757960 - Error Code 'IF'
Hi!!! You have a control board problem.Change the control board and you should be okay..Them boards did'nt come out good.Good luck..
SOURCE: Kenmore refrigerator model 46-66812 ice build up on the bottom shelf of freezer
Had the same problem. I noticed that the fan in the freezer never shut off so I suspected the thermostat. I ordered and installed a new thermostat (about $30 and 15 minutes to install), the fan now cycles correctly and the ice build up is gone.
SOURCE: freezer is very cold, refrigerator not cooling on Maytag side-by-
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
s
Hello friend, thank you for your post!
I understand that your Electrolux refrigerator is showing an "E3" error code. However, it appears "E3" is an invalid error code. May I have you model number please? Typically you can locate your serial tag (which lists your model number) on the inside cabinet of the fresh food compartment on the right hand side. With this information I can better assist you with pinpointing the issue. I look for forward to assisting you. -Matt
Hello p_shields123 - Could the actual error code display be "ICE T3"? If so, it typically indicates that the TH3 thermistor in the Fresh Food Ice Maker compartment is shorted or open. Regrettably, this is not a simple DIY job. I would strongly recommend connecting with a professional to move forward accurately and to properly assist with the repairs.
