Frigidaire cooktop model #FEC30S6AB front right burner heats only on HIGH and LOW nothing in between. How can I fix this?
The switch controlling the burner is just a voltage controlling unit (rheostat). It needs to be replaced
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
SOURCE: burner on electric ceramic/glass cooktop is getting too hot
sounds like you need a new thermostat
SOURCE: Front double burner not working on Jenn Air
mostly the problem is the sensor inside the unit but so very expensive to replace,wait to damage the other then buy an new one compare to repair.
tnx gerbee
SOURCE: Front burner won't ignite when turned on.
Hello there:
if you Heard or seen this poping you probably have shorted out the ignitor mechanism You can try unplugginh the stove and removing the part and inspecting it and see if it can be cleaned and doubkle check the wiring to see ithatthey are not greasy or there is any buiold up on the wires then reinsert the part and see if it will work now but if not you will have to replave the ignitor ok
If you have a local appliance repair center you should be able to get the part from there if not go online and go to www.repair clinic.com youcan order it from them ok
Hope this is very helpful for you
Best regards MIchael
Testimonial: "Thank you so much for your help.I am definitely going to take your advice. Working on it right now. Much appreciated."
SOURCE: Frigidaire Ceramic Cooktop PLEC36S9eca - Turns on but burners won't heat up
We are having the same issues it sounds like as Larry is...
SOURCE: I have a Frigidaire Ceramic Glass cooktop.the main
I'm having the same problem! Except I'm not guarenteed any heat even on high.
