Question about MTX Car Audio & Video
<!-- from fixya rte -->Do you have mtx wiring diagram? - MTX Car Audio & Video
How do I hook up 4 10 inch mtx old school?
you can put them in one box you will need a good port hole if you do.How to build subwoofer box
this link is on how to hook up speakers Subwoofer wiring diagrams \
good luck
Aug 11, 2015 | MTX Car Audio & Video
How to wire MTX 202 amp
this link has install sheets just match the model number of you amp to the list of mtx amplifiers to find appropriate wiring diagram
http://www.mitekasia.com/support/Default.aspx?sid=257&aid=2
Aug 13, 2014 | MTX Car Audio & Video
Need wiring diagram
i have a mtx tc4004 amp ..i want to run my dvc sub and my fronts
can i get a wiring diagram pleas
Feb 13, 2011 | MTX (TC4001) Car Audio Amplifier
How do i wire mtx 9500 subs 2 10'' down to a one ohm
THE T9510-04 SUBS ARE SINGLE COIL SUBS AND YOU CAN VIEW THAT WIRING DIAGRAM AT THE FOLLOWING LINK:
http://www.mtx.com/caraudio/products/subwoofers/TechData_T9510-04.pdf
THE T9510-44 SUBS ARE DUAL VOICE-COIL SUBS AND YOU CAN VIEW THAT WIRING DIAGRAM AT THE FOLLOWING LINK:
http://www.mtx.com/caraudio/products/subwoofers/TechData_T9510-44.pdf
SINCE YOU NEED A 1 OHM LOAD, I PRESUME BRIDGED AND ARE USING TWO SUBS, THEN HOPEFULLY YOU HAVE THE DUAL VOICE COIL TYPE, AS THEY ARE DUAL 4 OHM AND YOU WILL HAVE TO CONNECT THE VOICE-COILS IN PARALLEL WHICH WILL MAKE EACH SPEAKER A 2 OHM SPEAKER AND THEN CONNECT THE TWO SPEAKERS THEMSELVES IN PARALLEL AND THIS WILL PROVIDE YOU THE 1 OHM LOAD. IF YOU IN FACT HAVE THE SINGLE 4 OHM VOICE COIL VERSION, THEN IT WILL ONLY PARALLEL THE PAIR DOWN TO 2 OHMS. OK. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Jan 08, 2010 | MTX T9510-44 - 10" 9500 Thunder Series...
Wiring details
Hello bpuentes,
Here's a link to the wiring diagram PDF.
http://www.mtx.com/caraudio/products/manualsQuickInstall/amps/TA81001InstallWiring.pdf
Hope this helps.
Mar 30, 2009 | Car Audio & Video
Wiring details
thunder 81000D not bridgeable,i have two daul voice coils kicker cvr how would i wire them up?
Mar 30, 2009 | MTX Thunder 81000D Car Audio Amplifier
Ground Wire Hook-up
MTX has the hookup diagram here: http://www.mtx.com/caraudio/products/manualsQuickInstall/amps/RTP251D_InstallSheet.pdf If you have the original wiring harness, the ground wire is normally black. The amplifier case or chassis is ground connnected on amps I've seen as well.
Aug 06, 2007 | MTX Thunder 251D Car Audio Amplifier
Car Audio & Video Logo
61 people viewed this question
Top MTX Car Audio & Video Experts
Marvin
Marvin
Tom Chichester
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
