Why the machine dispense water very slowly in the cleaning process
There could be a calcium build up in the dispensing hole. Try to use something small to open the hole. I would try a paper clip. Straighten the clip and insert it into the hole slowly and work it in a circular motion. Then run water through again until you get the right flow of water. You don't have to use a paper clip, it can be something small enough to fit the drain hole. You could start with a needle.
Or have you tried to use vinager through the system. You might try to do the vinager first. Vinager acts like an acid which, in turn will eat the calcium build-up away. Good luck. These have worked for me.
How slowly in comparison to other units? Have you measured it how fast it runs ?? If slower than when Syntia was brand new is maybe caused by an insufficiently cleaned brew group or lack of proper descaling .Calcium or mineral in the unit's lines and boiler can slow down your machine .
if the filter screen is partially blocked from old coffee tar then water cannot flow faster . In my opinion it always runs slowly when rinsing .
If you use a "Coffee Residue cleaner "only use it in the pre-ground
setting chute and use only a pinch at a time . then run pre-ground setting without any grounds and run another one to clear the detergent
Very oily ,sticky coffee beans can plug up any late model superautomatic's system as you can read in the unit manuals . Because the laser cut holes in the fliter screen are so small that any coffee tar will not flow properly through the screens .I have had many machines which had to be switched to a less oily bean to work more than for2 or 3 cups .When beans are roasted too fast and too hot ,the coffee oil can turn to coffee tar .
My Xelsis unit cannot handle very oily beans . 2 cups and it STOPS
I only use beans roasted to American Coffee institute recommended procedures .
SOURCE: no hot water or steam
Well, I have little exposure to Saeco, but a lot to commercial coffee machines.
Saeco have a lot of custom made components, although these can be purchased, nothing is cheap! Neither is their repair service!
First, is the boiler heating?? If so:
No hot water/ no steam suggests a blockage. Assuming you can hear the pump working when attempting to do a coffee, you will probably find the water flowing back into the water tank via the relief valve. Of course, this valve itself could be the problem, or the pump failing to work through a blocked inlet filter or other problem.
Look now at the group head. Ever cleaned it? The filter and spray block should be removable, do so and clean them carefully. While you have them out, see whether water reaches the head by "making a coffee" into a cup placed under the head. BE CAREFUL OF SCALDING. If water now flows, cleaning the screen and spray block should restore operation.
Beyond that, it's inside the machine! There is a 3- way valve that operates when making a coffee. This can become clogged with coffee. There is another valve to open the steam.
If, like Saecos I have worked on, the boiler does both the hot water and the steam one at a time, look for problems BEFORE the boiler.
Hoe this helps a little....
SOURCE: water leaking from coffee dispenser
Hei dory may be this can be helpful.Inside the machine take out the brewing group on the back panel there is asmall metal piston with 2 small orange rubber o ring.Try to replace that(is not easy since the position)were the o ring are locate is very unconfortable but is something i believe you can do it.That one is the main connector between the inside and the conjunction with your brewing group.
Good Luck
SOURCE: Coffee dispenses extremely slow
try to change the grinder to little more coars, if it not help then i think it can be something with the printed circuit card.
Best regards
/Mirran
SOURCE: red water light is flashing
I read through many old posts and found the answer I was looking for. I turned the hot water nozzle on for 45 seconds and the problem went away.
SOURCE: Dispensing Failed- Saeco Talea Ring Plus
Try adjusting the grind four numbers coarser and brew a coffee, if you are getting the same result then the brew unit is clogged and the screen needs to be cleaned.
Hello - There are several things that could cause the fabric softener to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is fabric softener? If it is fabric softener, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the fabric softener dispenser with water. The fabric softener dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the fabric softener solenoid is energized and water flows into the fabric softener dispenser cup. When the cup is full the water siphons out and softener and water flow into the tub.
If the liquid in the fabric softener dispenser is pure softener you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the softener solenoid and a volt meter is required.
If the liquid in the fabric softener dispenser is water you probably need to clean the dispenser cup. **** will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the softener and overflow the dispenser cup and run into the tub. The instructions for cleaning the dispenser should be located on page 43 of the use and care guide that came with the washer.
If you don't have the use and care guide these instructions will help. Open the dispenser until it stops. In the left rear corner of the dispenser, there is a release that is labeled push. Press down on the push area and you can slide the dispenser drawer out.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the fabric softener compartment. When the water level goes above the maximum line stop pouring. The water should all drain out.
Hope this information proves to be helpful however if it is ineffective please contact a professional to move forward accurately.
