Question about Oregon Scientific Near/Far Weather Forecaster, BAR200A
Weather does not show up, what can I do more?
I put new batteries, everything is working except the weather forecast
S Sigs
    Master:
  • 406 Answers
It takes a few days before the unit will forecast. It has to collect the weather conditions for a period of time, in order to make a forecast (the barometric pressure, mainly).
Posted on Feb 14, 2016
Just put new batteries in both units but can't get the oudoor temp to show - what have ee done wrong?
Replacement has to be done in a certain order.
  • Remove all batteries
  • Install batteries in outdoor unit. Allow time for unit to initialize and begin transmitting temp.
  • Install batteries in indoor unit. You should see outdoor temperature displayed.
You may find that the outdoor temperature is not transmitted in very cold weather. Right now it is below freezing and my indoor unit is showing - - for outdoor temperature.
Dec 13, 2016 | Measuring Tools & Sensors
My station has quite registering the rainfall amount
This is nearly always due to the batteries not having quite enough power. Oddly enough, it is normally the battery in the head unit, not the satellite unit. Mine are powered by CR2032 button batteries. I buy them 10 at a time in a bulk pack from here.
Battery Buyer Batterybuyer com
Oct 10, 2016 | Klockit AcuRite 02001A1 Weather Station...
Why does outdoor temperature display only show = signs?
The outdoor sensor probably uses solar energy to charge a battery that powers the wireless transmitter. The battery may be defective or the charging circuit may have failed. The instructions that came with the station could provide some troubleshooting tips.
Nov 03, 2015 | Weather Channel WS-8500TWC-IT Wireless...
I have an acu>rite wireless weather station i have put in new batteries outside and inside still not working
Go to their website to get the instructions on how to re connect the transmitter after a battery change.
Jan 12, 2014 | Measuring Tools & Sensors
Outside temperature sensor not working
You probably need to replace the batteries. Be sure to follow the LaCrosse instructions exactly to get your Weather Forecaster working properly again
Jun 30, 2013 | La Crosse Measuring Tools & Sensors
Cannot get the weather station model ws-916ou-it to show outside temperature
I have three of these WS-916OU-IT units. After a few years, the outside sensor just fails. You will get dashes and a "TR" low battery signal, even if the batteries are good
just buy another whole weather station (short money) and set both the old and new weather station unit to receive from the single new outdoor sensor.
To do this - just follow the procedure for a single sensor - that is - put the batteries in the new sensor - then within 30 seconds - put the batteries in all the weather stations - they will all pick up the same outdoor sensor.
I now have three units running off of one outdoor sensor.
Seems a bit silly, but it works.
Feb 27, 2012 | Measuring Tools & Sensors
No longer shows temp (indoor or out) or weather. Outside unit is still working and showing temp.
Mine did the same thing. I just had to replace the batteries in the main unit and it is working again. Good luck!
May 22, 2011 | Leeds 805058 High Sierra Tahoe InOutdoor...
The weather Forecast Icons don't change on my honeywell weather station model # TE852W
This problem could arise due to various reasons
1)Replace the batteries in remote sensors
When the batteries are properly installed, the remote weather sensor will resume sending signals to the main unit.To enforce an immediate remote signals search, press and hold
DOWN on the main unit.
2)Remote thermo-hygrometer sensor could be weak in sending the signal about weather Forecast.Test it properly.
3)Reset the unit and check
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Sep 11, 2010 | Honeywell TE852W Weather Forecaster With...
Oregon Scientific Near/Far Weather Forecaster, BAR200A Logo
263 people viewed this question
Top Oregon Scientific Measuring Tools & Sensors Experts
Marvin
Marvin
Lawrence Oravetz
Are you an Oregon Scientific Measuring Tool and Sensor Expert? Answer questions, earn points and help others
