I nide driver
SOURCE: i have no hardware for win xp how can i
Hardware is the device. If the device doesn't work, go to the manufacturer's website and download and install the SOFTWARE.
SOURCE: Dazzle DVC-80 on vista thinks that video and audio are both audio
i did install the driver from pinnicle that says it will work up to xp.
its not hard but follow these steps, and ignore all these people that are saying it wont work, and throwing them out.
the problem, the install is not compatible with vista, so you change the compatibility of the file to xp pro. its easy here:
1. download the driver from pinnacle, its: PCLEUSB.exe
2. dont install it yet
3. right mouse click
4. hit the 'compatibility' tab
5. check the 'run this program in compatabilty mode for:'
6. scroll and select 'windows xp (service pack 2)'
7. also check the 'run this program as an administrator box'
8. click the 'apply button'
now:
click and run the file, its going to think its running under xp.
dont plug in the usb for the dazzle. wait for the install the driver.
when its done plug in the dazzle, it will look for the driver it will find it and will install it, since you ran the pcleusb.exe. hell the dazzle thinks its running in xp. now any software will use it and it will be in all you video software as the "dazzle dvc80" in video options and same for audio. works great, clean video and clean audio. just like new.
SOURCE: hi i have the the
Hi, Thanks for using fixya. If you are calling Dazzle Technical Support for the first time, or if you are within your 30 day free technical support window (30 days from placement of first support call), contact Dazzle at 203-315-4230. If you have extended beyond your free 30 day technical support window, contact Dazzle at 800-570-9548 (charges apply). We highly recommend having your computer nearby when
This is your owners manual:
http://cdn.pinnaclesys.com/SupportFiles/Downloads/Manuals/manuals/pdf/dvc100_En_ug.pdf
Here is your web support Phone numbers.
calling to facilitate troubleshooting.
Hope this helps:
Terry
If you have any further questions regarding this matter feel free to post a comment or if you are satisfied with my answer, please give it a rating for this is the reason I do this work.
