Question about Pioneer DVR-530H-S DVD Player/HDD Recorder
<!-- from fixya rte -->DVR-530 plays back from DVD but not from HDD - Pioneer DVR-530H-S DVD Player/HDD Recorder
I just got my Amino 530 DVR and have no idea how to operate it. Is there a manual on-line?
Hi we just got one and I was wondering if you ever found a operation manual on line?
Thx
May 14, 2010 | Cyberhome DVR 1600 DVD Recorder
I want to record a film off my camcorder directly on to the hard drive of my Panasonic DVR-645H-S DVD recorder. I have put the input plugs at the front of the recorder from the camera but cannot get a...
You have to select the correct External Input, on TV, you do NOT use "Channels" Then select correct format either NTSC or PAL, turn on camera to play, then you should be OK.
Mar 07, 2010 | Pioneer DVR-645H-S DVD/HDD Recorder
I am in australia and play region 4 dvds I want to but a region 1 dvd will it play?
HELLO
Not if your machine is locked to Region 4! It's possible there may be a region hack for your machine, have a look on www.videohelp.com and go to the hacks section.
To see if it will play try to borrow a region 1 disc. If it does not play, then you'll only be able to play Region 4 discs only.
ALL THE BEST (:-)
Oct 31, 2009 | Pioneer DVR-645H-S DVD/HDD Recorder
DVDs play in b/w only
This is because of wrong color setting(mode).Try changing the video mode from the menu ie, PAL/NTSC/AUTO from your TV or DVD(Ensure that both have unique color mode)
Mar 13, 2009 | Pioneer DVR-550HS HDD Recorder
What format are you recording in?If the recorder is set for DVD +R, and your playback machine won't read the disc, you may need to record on a DVD-R, or a DVD +-R. Or vice-versa. Some DVDRW discs will record on one machine and won't play on another. The media are incompatible. Another problem - if you are copying a copy-protected disc, it might not play back either. Are you sure you are finalizing the disc? This process takes 4-5 minutes and requires two or three responses sometime.
Dec 03, 2008 | Cyberhome DVR 1600 DVD Recorder
How to upgrade hdd for Samsung DVR HR737
If you want to play your videos from your computer to your dvd the best way i have found is download realplayer when its downloaded and your ready to go. Go to burn and transfer cd in the options on the burn page at top it lets you change formats.The format you need to use to go from computer to DVD player is vcd it has a DVD format but i don't have a DVD burner so i haven't tried that format yet.Hope this might help.
God Bless Greg
Here is address: http://www.real.com/ i use the free and it works great
Nov 11, 2008 | Compaq EVO D510 CMT P4 2.5/20GB/256MB...
Movie regions
Go to: www.videohelp.com what you are looking for is a region free hack..put your machines numbers in, hit search, scroll down, look to right of screen to see if a hack is listed.
Jun 26, 2008 | Pioneer DVR-640H DVD Recorder/HDD Recorder
My dvd player will not play HD-DVDs it is an HD DVD player
This dvd player doesnt' play HD DVD's it has a HDD which is short for Hard Drive. Which means you can use it like a DVR (Digital Video Recorder) to record your favorite shows and things like that.
Does this answer your question? If not i'm not sure what you're trying to ask could you be a little more elaborate?
Jan 25, 2008 | Samsung DVD-HR735 DVD Recorder/HDD...
Digital audio problems
Try using a different cable for starters, regular rca, another optical or coaxial. If the optical works, then its a cable problem. If the coaxial works(and another optical doesnt), then its a cable/jack problem. If the RCA works(and the rest don't), then its a problem with the digital output. Try blowing into the holes, and if nothing works and you can't find any other advice, contact Pioneer. Good luck
Mar 11, 2006 | Pioneer DVR-5100H DVD Recorder
Pioneer DVR-530H-S DVD Player/HDD Recorder Logo
26 people viewed this question
Top Pioneer Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
