forums.digitalspy.co.uk/showthread.php?t=1687936 Digital Spy
Jul 5, 2012 - 13 posts - 2 authors
Cheapo MP3 play with rewind and fast forward Tablets and e-Readers. ... can anyone recommend a cheap MP3 player that will allow you to fast forward, ... the yepp yp55 t had a wonderful "scroll through" function that took ...
Touch the screen, and 'reverse', 'pause', and 'forward' icons will momentarily appear on the lower portion of the screen. Before the icons vanish, touch either the forward or reverse icon and continue to hold your finger on the icon without lifting it off of the screen. Fast forward or rewind will then begin, at a rate of 5 seconds per second held. I am told after holding for 15 seconds or longer the speed of the fast forward may increase (true for other Coby models I have owned), but so far I have had no luck getting this to occur with my MP828.
something maybe broken on the inside for it to say play but fast forward. the botton could be stuck as well. maybe open the vcr and clean it all up in side. that might help
Hi, Does the tape move when you press rewind or fast forward. If the tape moves for a few seconds then bleeps it sound like a sensor problem. If it only bleeps when the rewind and fast forward are pressed and the play is ok it sounds like the actuator motor is faulty,this motor enables the rewind and fast forward. Hope this helps.
you may want to try fast forwarding at 2x (that is, press the FF key twice), although the speed will be faster, it may actually stop for you, when you press play, rather than going to the end.
If you asking about avi file there is no easy solution of this problem because Windows Medai Player as well as Windows Media Center can not fast forward and rewind avi file only DVD support fast forward - you need to use 3th part software (player) to be able to do fast forward,
I spent a lot of time trying to force WMCE and WMP to FF all files no lack so far
Enter the security code using your Kenwood remote. For the DDX6019 The key sequence to enter the security code KCAR is: on the side of the remote there is AUD, DVD,TV. now enter 55 in the AUD then go to DVD and enter 2 which is fast forward then go back to AUD. Do the same for the rest. 5 5 fast forward 2 2 2 fast forward 2 fast forward 7 7 fast forward
Enter the security code using your Kenwood remote. For the DDX6019 The key sequence to enter the security code KCAR : on the side of the remote there is AUD, DVD,TV. now enter 55 in the AUD then go to DVD and enter 2 which is fast forward then go back to AUD. Do the same for the rest. 5 5 fast forward 2 2 2 fast forward 2 fast forward 7 7 fast forward
