Question about Refrigerators
How do i clean the cleaning coils on my GE Profile refrigerator, model PSHS6RGX?
Thomas Beaver
  • Refrigerators Master
  • 2,119 Answers
5 Related Answers
christian nielsen
  • 358 Answers
SOURCE: Can't find refrigerator coils/ cooling issues
There're two coils ,the condenser coil wich you already clean (also make sure the condensing fan motor works properly and the fan blades are also clean).The other is the evaporator coil wich is located inside the freezer behind the back wall cover.
Posted on Apr 21, 2009
taran_2005
taran_2005
  • 10515 Answers
SOURCE: GE Profile Refrigerator model #TXP24PRYE with yellowed handles
Spray with clorox all purpose cleaner and scrub it with hot or warm damp wash cloth.If the handles are plastic, Krylon makes an excellent line of spray paint products that bonds to plastic and adheres to the surface. Most spray paint products only coat the plastic and on a surface like a handle that will be used constantly, is easily scratched or peeled. The Krylon plastic paint bonds to the plastic surface and is very durable. The one down side is if you paint the handles and don't like the results, there is no going backwards, you can't remove the paint once it has cured.
Thanks.
Posted on Jun 19, 2009
Anonymous
  • 1218 Answers
SOURCE: The GE Profile of 13 years old makes a loud bang
Good day,
If it makes the clunk or banging noise when the compressor is shutting off, then yes, internal spring or springs inside the compressor have broken.
Only solution to that problem is a new compressor.
P.S. these things can run a long time with this condition, but ultimately .....
Thank you for using FixYa
Posted on Dec 25, 2009
Testimonial: "Thank you for your info. You were very helpful."
Sea Breeze
John Tripp
  • 4656 Answers
SOURCE: GE Side by Side Refrigerator no longer cooling.
If not cooling or signs of not defrosting we will need to check the compressor start components, fan mortors and motherboard. Let me know and I can guide you through this. Sea Breeze
Posted on Apr 05, 2010
Testimonial: "Hi Sea Breez. I have ordered and replace the defrost heating element. I'll check the coils in a day or two. Thanks for providing the service manual!"
jumptrout51
steve
  • 3361 Answers
SOURCE: how do I go about 'cleaning the coils' on a GE
It is not necessary to clean the evaporator coil.
The condenser coil underneath may need cleaning.
Use a long handle bottle brush and a vacuum cleaner.
Your refrigerator freezer temp will fluctuate from minus 5 degrees to plus 18 degrees on a regular basis.
It will not be a steady temp.
Posted on Jul 24, 2010
GE Profile 21 cu ft. goes continuously except upon defrost, "once a day" for about 30 minutes. Unit cools both on freezer side and refrigerator side (ice cream ok and milk ok). Repairman...
open the doors and feel the middle strip.if that's hot check the condenser fan to make sure it's running and clean out the coil in the back.pull out the machine,remove the bottom panel,on the right side you'll see the coil,with a shop vac vac off the coil and then put it on blow and blow out the coil,that's the only way to clean this kind of coil and make sure the fan is blowing back there.let me know what you find,also send the full model number,open the fridge door,look at the right wall near the ceiling and you should see the model number.
Jan 23, 2011 | GE Profile Side-By-Side Refrigerator with...
My GE Artic Profile refridgerator blows warm air on both sides Model number PSS25MGNAWW SER #420869
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then checkout the last two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 17, 2010 | GE Profile Arctica 25.4 Cubic Feet...
MY GE PROFILE REFRIGERATOR DOES NOT COOL IT SHOWS 7 ON THE DISPLAY AND THE REFRIGERATOR SECTION DOES NOT FREEZ ANYTHING IT SHOWS 4 AS TEMPERATURES.
ck the fans and clean the coil underneath / dirty coil will cause poor cooling and fan that is not going or is going too slow .. mm
Sep 01, 2010 | GE Profile PSW26P Stainless Steel Side by...
How do I go about 'cleaning the coils' on a GE profile model - freezer is having trouble holding 0 F and I was told this would help. thanks
Jul 24, 2010 | GE PDS22SBRLSS Bottom Freezer Refrigerator
GE Profile refrigerator temperature problem
refrigerators have 2 coils. the evaporator coil and the condensing coil. one is on the bottom of the fridg and one is on the back or inside behind a false panel. these coils must be kept clean or if the condensing coil cannot reject the heat absorbed by the evaporator, the box temp will stay high and if the evap coil cant absorb heat the box temp stays low running the risk of freezing
Nov 26, 2009 | Refrigerators
GE profile counter depth side by side stopped
Is the compressor coming on at all? If not a capacitor may be bad .
Jul 05, 2009 | GE GSH22JFR Side by Side Refrigerator
Refrigerator is freezing
try cleaning out the coil....if you havent cleaned it dirt will block air flow causing erratic temps in the refrigerator section
Jul 30, 2008 | GE Refrigerators
GE PRofile Arctica
Just had mine with the same problem fixed today,it was the main board on the rear of the fridge,common problem with these models told by the tech.
I believe you can get a free board fom ge but you pay labour
Jun 17, 2008 | GE Profile Arctica Stainless Steel Top...
Refrigerators Logo
784 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
john h
