Honeywell RTH3100C - Digital Heat Pump Thermostat Logo
B
Bob Wing Posted on Aug 30, 2014
How do you relpace an A.C. thermostat?
Changing out my thermostate with non programmable.Which wires go where? Old wiring as shown. B - NO WIRE, O - ORANGE WIRE, W2 - WHITE WIRE AND A JUMPER GOING TO E, G - GREEN WIRE, E - JUMP WIRE GOING BACK TO W2, Y1 - YELLOW WIRE, Y2 - NO WIRE. NEW THREOSTAT TERMINALS: e - aUX - Y - G - O - L - R - B - C. New one is a Honeywell RTH3100C. Thanks for your help. Bob
Stephen Brisbois
Level 1:
  • Contributor 44 Answers
  • Posted on Aug 30, 2014
Stephen Brisbois
Contributor
Level 1:
Answers
44
Questions
Helped
11394
Points
65
E Back up heat/ white wire
AUX Jumper to E
Y yellow wire / Cooling - compressor
G Indoor fan Green wire
O Reversing valve energised in cooling most units Orange wire
L unknown. consult your manual Leave open
R Main power Red wire
B Reversing valve energised in Heat Rheem units only.
C Common second leg of power Blue wire.
  • 1 more comment
  • Bob Wing
    Bob Wing Sep 01, 2014
    To Stephen Brisbois
  • Bob Wing
    To Stephen Brisois. You answered my question on or about Aug. 30th. Relaceing thermostat with a Honeywell RTH3100C. Everything sounds good, but I only have 4 wires coming in. White, orange, green and yellow. If I follow your instructions and don't have a red wire on R or a C (Common second Leg blue)
  • Stephen Brisbois Sep 02, 2014
    Someone has done some creative wiring to your system. You will have to get into the air handler / A/C and see where each of thoes wires are connected. I would call a professional to avoid any damage due to miss wiring.
How to wire a honeywell ct410b 4 pole thermostat to a fahrenheater model fuh724 ceiling heater.
Similar Options to ConsiderSee All
Cadet Double-Pole 22 Amp 120/240-Volt Wall-Mount Mechanical Non-programmable Thermostat in Almond
(26)
$3217/each
Cadet Double-Pole Electric Baseboard-Mount Mechanical Thermostat in White
(84)
$2498/each
Economy Heat/Cool Manual Thermostat
(128)
$1888/each
Wireless PTAC Wall Remote Thermostat
(0)
$18482/package
tekmar Radiant 519 - Digital Non-Programmable 1-Stage Heat Thermostat with Slab Sensor 079
(3)
$11563/each
White RodgersB30 Baseboard Non-Programmable Thermostat - Single Pole
(1)
$1256/each
Broan Cold Weather Non-Programmable Solar Power Attic Vent Thermostat
(0)
$986/each
Was $24.66
Fahrenheat Non-Programmable Wall-Mount Thermostat
(18)
$2074/each
White RodgersB50 Baseboard Non-Programmable Thermostat - Dual Pole
(6)
$1999/each
Cadet Single-Pole Electric Baseboard-Mount Mechanical Thermostat in White
(42)
$2198/each
Cadet Double Pole 15 Amp 208/240-Volt Digital Electronic Non-Programmable Wall Thermostat in White
(72)
$5808/each
Model # CT410B Internet #100574426 Store SKU #129002
Honeywell Manual Electric Baseboard Thermostat (123)
Questions & Answers (32)
  • Manual 4 Wire Premium Baseboard/Line Volt Thermostat
  • Compatible with 120, 240 and 277 vac baseboard heat systems
  • Simple dial-type mechanical control
Quantity -
+ store iconPick Up In Store
Unavailable at Guam - Tamuning
Check Nearby Stores package iconWe'll Deliver It to You
UnavailableDelivery is unavailable for this product Your local store: Guam - Tamuning
Store Details & Services Accessories (1) Product Overview
The easy-to-install Honeywell Manual Electric Baseboard Thermostat works on 4-wire (double pole) electric heat applications (baseboard or line volt) and allows for simple, worry-free operation. It has a simple dial-type mechanical control and is UL and CSA listed for safety.
Info & Guides
You will need Adobe® Acrobat® Reader to view PDF documents. Download a free copy from the Adobe Web site.
Compare Similar Non-Programmable Thermostats
Price $21.99/each $24.97/each $44.28/each null¢ /null Name Double Pole 4-Wire Line Voltage Mechanical Thermostat Digital Non-Programmable Thermostat Single-Pole 10.4 Amp 120/240-Volt Digital Electronic Non-Programmable Wall Thermostat in White Manual Electric Baseboard Thermostat Brand Lux Honeywell Cadet Honeywell Ratings View Product View Product View Product View Product Specifications
Dimensions
Product Depth (in.)
1.5
Product Height (in.)
4.5
Product Width (in.)
2.75
Details
Color Family
Whites
Color Family
White
Operation Type
Mechanical
Returnable
90-Day
Shape
Rectangle
Thermostat Product Type
Thermostat Shape
Rectangular
Thermostat Type
Heat Only
Voltage (v)
110/240v
Voltage (volts)
110/240
Warranty / Certifications
Certifications and Listings
1-UL Listed,CSA Listed
Manufacturer Warranty
1 year limited warranty
How can we improve our product information? Provide feedback.
Wiring diagram thermostats
Look at the base plate just below the w position. This is the correct placement for heat pumps.
Im in a apartment just moved In and the honeywell thermostate im replacing with a hunter brand, non-programmable thermostate, there was only 3 wires hooked up, out of the electrical wiring theres a red...
Need to know if you have central air as well. If you don't, then hook up the Red to R, White to W. you @ least have heat. any other wires you hook up will be dependent on what type of system you have ie boiler, forced air, etc.
I am changing an old thermostat, and converting it in to a honeywell RTH2310B. The original thermostate has 3 wires, in red,black, and white. The new one has white, yellow, and green. How do I proceed?
Hi, the new stat should have rh, and rc, with a jumper wire on it. leave it on, and connect your red to either one. Connect white to W, and the black the must be using for fan, so connect it to G, if it was being used on the other stat. If it wasn't, tape it off. You should be up and running. I take it this is a heat only application.
Sincerely,
Shastalaker7
A/C, & Heating Contractor.
Where does the blue wire go?
GET THE D GRAM FROM HONEYWELL USER MANUEL SOPPORT
2helpful
I need a wire diagram of a central heat and air with a heat pump
W- White (heat)
Y- Yellow (condenser)
G- Green (Indoor fan)
C- Blue (Common 24v)
R- Red (24VAC)
O/B (Only needed if system is a heat pump)
1helpful
Upgrading Thermostat
Looks like your system is a heatpump system and that t-stat will not run a heatpump , you need a t-stat for 2heat and 1 cool systems
Wc wiring on thermostat
sounds like you have a heat pump the w2 on old thermostat is for a second stage heat. If you can give me a little more information on type of system you have (forced air furnace with heat/cool, Heat pump or boiler)? How many wires are on old thermostat? Is it a no programmable or programmable? How old is the furnace?
1helpful
2answers
Honeywell thermostat
If you have a forced air furnace with an air conditioner attached make sure you have a jumper wire between Rh and Rc. If the Bryant thermostat had a wire hooked up to C you do not want to hook this up to Rc. Just cap it off and put it back in the wall or disconnect that wire down in the furnace.
Top Honeywell Heating & Cooling Experts
Paul Carew
john h
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
