Autorun problem espresso machine nwill not start up
SOURCE: espresso gaggia titanium. Water Tank leaking
The o-ring on the bottom of the water tank is either missing or not seated properly.
SOURCE: gaggia titanium espresso ventilate is on the
Hi
When you push the water button, then open the steam knob. This will allow water to flow. If you don't get water to flow check the water tank and make sure that it is down on the machine completely. The other thing that will not cause water to flow is a restriction in the flow meter.
SOURCE: My gaggia titanium says it's brew unit is blocked
Try cleaning and relubing the brew unit.
If that fails you require a new main board.
SOURCE: Gaggia Titanium Espresso machine problem: steam
Normal, depending on the amount, when the hot water goes through the coffee and the pressure builds up the excess has to go somewhere when it stops, usually the drain tray, so there is a little steam loss.
