Question about Rubinet Home
Is it possible to adjust shower mixer temperature?
I've adjusted the hot valve all the way in (almost off) and the cold is all the way out (completely on) but I still can't get the shower to be cold. I've also turned my water heater down to it's lowest setting. Is there another adjustment that I can make to where the water mixes (other than the regular temperature adjustment? The regular temp. adjuster is all the way to cold, but it's still too hot.
mirsheharyar
    New Friend:
    Problem Solver:
  • 18 Answers
Now my best guess is that you kept heater too high for a long time which means that the pipe carrying hot and cold water got touched and water became hot So turn off the heater for while and let the pipes cool off then turn the heater on at a low setting ...
Posted on Aug 30, 2014
2 Related Answers
Randy Marshall
  • 349 Answers
SOURCE: adjusting the scauld guard on a shower mixer valve
Uue a 1/8" allen wrench to remove handle to access the dial that set's the mixture of water.Remember or mark where it is and remove and reinsert counter clockwise about a 1/4 turn to start to you reach desired temperature setting. Be careful not to set it at a hot enough setting to burn you.
Once dial in place slide handle on and turn on to check water temperature.
Posted on Aug 01, 2010
Magaiver
keith macisaac
  • 707 Answers
SOURCE: Valve will not mix enough hot water with
Their is a mixer valve if it is a one handle unit which is built in. It may be one half turn out of timing.
Posted on Aug 10, 2010
Our bath taps which are a mixer with shower attachment stay really hot if you put the hot on first or really cold if you put the cold on first any idea how to adjust so we can have warm water when turning...
you make no sense. From the picture the water "mixer" is the center lever or is it a diverter valve for the shower and water nozzle below???
The knobs are for hot and cold water??
Jun 08, 2014 | Plumbing
Why do I only have hot water in the shower
sounds like either the cold water that feeds the other half got shut off, or the mixer in the valve for controlling the water temperature is broken....most likely the water got shut off. better go to the water source and trace the cold water feed pipe ,looking for a shut off valve....it could also be behind the shower panel, then turn or rotate the valve the other way and go test the water to see if you can adjust the temperature now.....if not, then replace your hardware.......in the mean time, you could turn the temperature down on the water heater so that you won't scald yourself in the shower til you have time to fix it properly.
Apr 26, 2012 | Moen Home
I have a hudson reed Twin Concealed Thermostatic Shower Valve. It was working fine for a couple of years. My brother used the shower and adjusted the water temperature valve but since then the water has...
Sounds to me the diffusor is stuck or broken in the position to allow only hot water through it.Looks to me tou have a mixer valve on it. Might have to replace it.
May 31, 2011 | Hudson Reed Home
I have an emco equitemp shower valve and have recently installed a tankless water heater. I need to adjust the valve so that the hot water temperature is higher. The water heater heats at 140 degrees but...
You should have the ability to reach 185 degrees. As long as the Heater is capable of reaching 185 you should be able to process that extreme without a problem. The only reason you cannot get above 140 is because the valve is limited or defective. You may have to replace the shower valve to accommodate 185.
Feb 05, 2018 | Home
Adjusting the scauld guard on a shower mixer valve
Jul 31, 2010 | Delta & Single Handle Shower Faucet
Temperature too hot on bristan art deco mixer shower even on lowest temperature setting.
if the water is that hot then lower [adjust] the temp of your hot water heater -if need to adjust the shower you can adjust the mixing by removing the handle and on the valve stem are the adjusting clips the red [hot] and blue [cold]plastic clips can move them around to adjust the mixing of hot and cold water
Jul 23, 2010 | Home
Thank you for reading this. I am a non-technical home owner. I have a Groge Atrio shower with a thermostat mixer in the wall. The water does not get hot enough so I need to adjust it upward. Do I remove...
You didn't mention what model you have. Here is a link to their web site. You can download a manual, that has detailed instructions on how to adjust. You should have a thermometer to measure water temperature to adjust properly. Go to : http://www.groheamerica.com You can identify your model, and then download the technical product information. Also check the temperature of other faucets in the house to be sure they are getting hot enough, and not a water heater temp problem.
Jun 30, 2010 | Home
I have A whirlpool hot water heater I can get hot water downstairs but not upstairs through the shower and tub
Upstairs do you get hot water to your sink faucet. If you do this indicates to me that the temperature valve in your Shower & Tub may need to be adjusted.
For single handle please remove handle to gain access to dial that adjusts hot & cold water mixing.
Remember where it is and take it out and replace about a 1/8 to 1/4 turn counter clockwise and reinstall and try.
It is a plastic adjustment dial that will slide off after the handle is removed.
Trace lines if possible to assure correct pipe's are connected to valve.
May 20, 2010 | Home
Not enough hot water, has to do with a shower valve
Hello, first if any water supply hot or cold is turned off, you will experience trickling as you mention. You must have both cold and hot in order to adjust the temperature on your valve. if you had a plumber intall this unit you should ask him to adjust it. Otherwise here is how:
Rotate the handle counterclockwise to stop and let water run till cold water is purged, check
temperature. Rotate handle to off, remove handle parts (see Disassembly in your manual) and temperature limit stop, rotate clockwise to decrease and counterclockwise to increase maximum hot water temperature, reinstall temperature limit stop and handle (TIP: Do not screw handle in until desired maximum temperature is achieved) Repeat steps until desired maximum
Feb 21, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Home Logo
320 people viewed this question
Top Rubinet Home Experts
john h
Tom Chichester
Are you a Rubinet Home Expert? Answer questions, earn points and help others
