Question about Oster 12-Bottle Wine Cellar - Black
How are beaded wine bottle covers made with string?
What size beads are best suited for use to make the wine bottle cover?
Posted by Gina Misner on
2 Related Answers
jschack
SOURCE: How do you replace the Oster 12-Bottle Wine Cellar Fuse
how do you replace the fuse?
Posted on Sep 30, 2008
Anonymous
SOURCE: oster 12 bottle wine cooler
You must remove the fuse from the circuit board to check it. More than likely it's blown. A continuity test while in the circuit will always show the fuse as being good due to feedback through the circuitry.
Posted on Nov 22, 2008
I bought some beautiful beads for making necklaces etc but some of the holes are just a bit too small for the thread. Is there anything I can do? It seems such a waste not to use them.
Do you have a bead reamer? If you bought a starters jewelry making kit, you might have got one with it. If not, you can buy one for quite a good price. Bead reamers are good for smoothing down rough edges on beads but can also help to enlarge holes on beads.
Jan 10, 2013 | Crafts & Hobbies
What do I replace the little red bead with?
I superglued a bead close to the exact same size in it's place and it worked for me. The bead must be round and smooth (w/o any glue residue or hole on exposed surface that the ball touches on) else the movements are a bit jerky and it's hard to control. Hardest part is finding that bead size. Perhaps a bead store?
May 19, 2012 | Kensington Expert Mouse Trackball
I have grime in between the two glass panes. How do i dismantle it to clean without damaging it? It seems to be glued
You will probably have to remove the door. On the inside there should be a beading which can be removed very carefully as not to break it. you can then remove the inner pane and clean, Be very careful. run a hair dryer around the beading to warm it up so it becomes flexible. but take great care.
Apr 17, 2010 | Haier BC112G Wine Cooler
String with beads hanging under marauder right headlight???
it's probably some mardi gras beads that the car wash machines threw at your car just cut them off
Jan 11, 2010 | 2004 Mercury Marauder
Oster 12-Bottle Wine Cellar - Black Logo
98 people viewed this question
Top Oster Furniture Experts
Tom Chichester
ray gallant
Are you an Oster Furniture Expert? Answer questions, earn points and help others
