Need code for aveis tv/dvd combo
HI,
CHECK THE FOLLOWING LINK
Electronics Equipment Repair Center RCA UNIVERSAL REMOTE CONTROL 4 DIGIT...
SOURCE: remote control code/daenyx tv/dvd combo
Your TV is made by Daewoo and is distributed by Daytek. If you call the 800 number on the warranty card you will reach Daytek.
So, what you need to know is this:
#1. A lot of new products won't have a website available. That does not
say anything to their quality or the company, just that you've bought a
new product and you're one of the first purchasers.
#2. A lot of times if you buy a "no name" TV, you're actually getting
components inside the TV that are made by brand name manufacturers. For
example, "Prima" uses LG panels in some of their plasma TVs (as well as
Daytek). How do I know this? Because I'm the authorized service
provider for Daytek, and Prima and quite a few other "no name" TVs, and
I've been working on LCD and Plasma since they came out, as well as
having worked in the electronics repair industry for over 20 years. I
own an Insignia 42" LCD and am quite happy with it.
#3. Most new products that have remote controls will not have codes
available for them no matter what brand of universal remote you buy.
You have to wait for the people who make the universal remote to have
time to make a code for this new brand of TV. This can take up to a
year for cable companies, and cheaper universal remotes may never get
the code. Expensive universal remotes may be able to have their
firmware updated through the internet, so adoption of new codes for new
products may happen faster.
#4. Stores like Walmart and Costco are excellent places to buy products
like this because they usually have a "no questions asked" return
policy if you get the TV back to the store within the stores time limit
for returns (some stores are 15 days, some are 30 days, phone the store
and ask them). I had purchased a 40" Digistar LCD TV from Walmart what
had a flickering problem, I took it back the next day without any
problem at all. Then I bought a 42" Insignia Plasma TV from Future Shop
that I wasn't happy with. I took it back 3 days later and had no
problem at all. As long as you know the stores policy for returns and
follow the policy, you won't have any problems either.
#5. Try to avoid buying big-ticket items from smaller stores unless you
know their return policies. Some smaller stores will not accept returns
on LCD monitors, TVs or plasma TVs but instead require you to
handle any problems through the manufacturer.
#6. Best bet it to call Daytek and ask them if they know of any universal remotes that work on that particular model.
SOURCE: Need code for Emerson TV,DVD,VCR Combo
I don't have a code book for you, but I can tell you how to program the RCR660 using the automatic programming feature.
Programming RCA model RCR660 (no code search button)
While following these instructions, keep the following in mind:
device = the component you wish to control with your remote (TV, DVD, VCR, etc.)
DEVICE = the button labeled for the component you wish to program
1. Turn on the device you wish to program.
2. Turn off all other devices in the general vicinity.
2. Press and hold DEVICE
3. While holding DEVICE down, press ON/OFF and hold them both down until the LED turns on for that device.
4. Release both buttons.
5. Point the remote at the device, press and release PLAY and wait 5 seconds or until the LED stops flashing.
6. If the device does not turn off, then continue to press PLAY and wait the required interval (for a maximum of 20 times) until the device turns off.
7. When the device turns off, press REVERSE, wait two seconds and continue doing this until the device turns back on.
8. To finish programming, press and hold STOP until the LED turns off.
you can set up any like this
1. turn on what ever you want set up
2. press and hold set up tell light blinks or stays lit
3. push what you are trying to set up t.v. or dvd ect.
4. push power on/off tell it turns off
5. push enter when it turns off
Thank you for useing fixya please rate me
I don't know if you guys even need this advice anymore, as it's 1-2 years late, but if your universal remote has a VCR setting, the Emerson 13" CRT TV/VCR combo I have operates under that mode.
The code I used was 002. These may also work: 278, 184, 479, 000, 121, 211, 037, 043, 061, 208
Remember, program your remote as if you were setting up a VCR (and NOT a TV). For instance, on my GE universal, I hold the "code search" button down until I get a steady light. I hit VCR, and then I entered 002. Works like a charm.
