The touch screen works fine it lets me click on apps play games and type it's just the home, menu and back touch buttons that don't work at all. can i fix this?
I was going through all the files and things on the phone one day and stupidly deleted alot of files that i thought were useless and just taking up my memory. I think this has something to do with it but because i'm not as knowledgable as I originally thought in phones I havent figured out if it's possile to fix it or how.
SOURCE: SE K850i menu touch screen button not working properly
you need to have the phone service you need to take the phones in and have them check.
SOURCE: LG Vu screen has frozen
It sounds like the touch screen/digitizer is broken This is the front of your phone that needs replaced. can be fitted by yourself if you buy ne onlne, prob not worth getting repaired by a repair centre if you are trading it in. You may be best selling it online for parts.
SOURCE: Apps not working
did your phone automatically update?
there is a new version of the iphone software and it may be incompatible with your apps.
SOURCE: Blackberry Storm: My Menu button and end button do not work
This problem happened to me and I just figured out the answer. If you recently installed a new application or a new theme then it will probably mess with your button configurations. Remove the theme/application you installed just before the problem started happening. Once you removed the theme/application convert back to the default theme and your buttons should work again.
SOURCE: iphone home button not working due to water damage
If you are familiar with repairing electronincs I would recommend opening the unit up and inspecting the internal components of the home button and the corresponding logic board connecting point for corrosion.
You can get a new home button for about $6 on eBay. Just eBay search for iPhone Home Button.
Hope this helps, Please Rate Me!
