Computers & Internet Logo
A
Anonymous Posted on Aug 30, 2014
How can i clear memory on Casio SE-S300 for new business?
TheTopMostDog
Level 2:
  • Expert 100 Answers
  • Posted on Aug 30, 2014
TheTopMostDog
Expert
Level 2:
Answers
100
Questions
0
Helped
26530
Points
268
Www.manualslib.com/manual/25917/Casio-Se-S300.html
This might be of help. I had a quick browse through it, but couldn't find reset to factory defaults in the contents. I'm sure it will have what you're looking for, though. Good luck.
5 Related Answers
jackcity
jackcity
  • 34 Answers
  • Posted on Nov 15, 2009
SOURCE: I am using a SE-S300 and can not clear a E001
E001 = Wrong Mode, which means u had did something in another key mode but not yet done.
Solution 1 :
1. Turn the key to another position where the screen do not show E001
2. Press [Subtotal]
3. O.K
Solution 2: Flag Clear the Machine
1. Key turn to OFF
2. Keep Press [FEED]
3. Key turn to PGM
4. Release [FEED]
5. U will see "INIT 0000000000"
6. Press [Subtotal]
7. U will see "FFFFFFFFFF"
8. Wait for 10 seconds, the machine will print
9. OK
Anonymous
  • 737 Answers
  • Posted on Sep 27, 2010
SOURCE: i want to reset this casio se s300...how can i do?
Reset what? If you mean the daily report, then turn the key to Z mode and press cash. If you are talking about removing programming, it is best to edit the existing programming so you don't lose system settings. If you need a manual, there is one here http://the-checkout-tech.com/manuals/cashregisters/Casio_SE-S300_users_and_programming_manual.html
Anonymous
  • 150 Answers
  • Posted on Jan 07, 2011
SOURCE: I bought a second hand register casio se-s300. can
Turn key to PROGRAM mode. Turn power off at wall. Hold FEED down - keep your finger on it. Turn power on at wall. Wait 5 seconds, then let go of FEED. Press SUBTOTAL.
After power on. You are ready to get going.
Electroboy
Electroboy
  • 1888 Answers
  • Posted on Mar 10, 2011
SOURCE: plz solve my problem casio
If the register is new, this is normal, it just needs programming. Otherwise, it may have had a lock up.
Try this: Turn key to PROGRAM mode. Turn power off at wall. Hold RECEIPT FEED down (may just be called FEED) - keep your finger on it. Turn power on at wall. Wait 5 seconds, then let go of RECEIPT FEED. You should see "FFFFFFFFFF" on display. Press SUBTOTAL. Wait for print out. Turn key back to REG mode and try it.
If anyone needs more information, the Casio SE-S300 manual is here: http://the-checkout-tech.com/manuals/cashregisters/Casio_SE-S300_users_and_programming_manual.html
Anonymous
  • 52 Answers
  • Posted on Sep 14, 2011
SOURCE: How to reset factory settings on a Casio SE-S300
How do I reset the cash register?
116ER, 117ER, CE2300, CE2350, CE2400, CE280, CE285, CE300, PCR202, PCR204, PCR308, PCR408, PCR350, PCR355, PCR360, PCR365, PCR450, PCR460
This will erase all information - Remove AA batteries and unplug register from wall for 15 minutes.*
If resetting does not work this indicates issue is repair level.
PCRT465, PCR465A, PCRT2000,
This will erase all information - with the PGM key at Off press and hold down the Feed button, while holding the Feed button turn the PGM key down to the PGM mode Release the Feed Button ----INI should appear or a group of 8 zeros
PCRT470, PCRT480, PCRT48S, PCRT2100, PCRT220S
This will erase all information - with the PGM key at Off press and hold down the Feed (journal) button, while holding the Feed button turn the PGM key down to the PGM mode Release the Feed Button ----INI should appear or a group of 8 zeros, now press one of the below
22500 Subtotal (PCRT40, 480, 48S)
Or
23000 Subtotal (PCRT2100, 220S )
Wait for a receipt to print.
1helpful
Casio SE-S300 ERROR 004
This Casio error code normally means there is no programming in this machine and it is waiting to be fully re-programmed. If the machine is new, this is normal since it will have no programming yet.If you need an SE-S300 programming manual, one of our users has it here:
5helpful
I have a SE-5300 Casio cash register and I want to reset everything.
I think you mean an SE-S300. If so, pull a battery out. Turn key to REG mode. Turn off at wall, then back on. Put battery in. Be aware that this will lose all programming and sales data. You will need to re-program from scratch.
If anyone needs a Casio SE-S300 manual, the programming manual is here:
Casio se-s300 int number
This means the machine has no program.
Try taking the batteries out, turn key to REG mode, turn power off for 5 minutes, then back on. Put batteries in.
If anyone needs a Casio SE-S300 manual, try here:
3answers
How do i programme prices on the casio SE-S300 till?
Turn key to Program 1 SUBTOTAL price (no decimal point) Item button SUBTOTAL
The Se-S300 manual can be found here: http://the-checkout-tech.com/manuals/cashregisters/Casio4.php
I am trying to clear a SE-S300 Casio Till of all prior transactions, clerk numbers etc to enable a complete new programming proceedure. I have turned the PGM key to the "off" position, held down...
Are you sure you understand the full programming including machine features setting, memory number programming, department, PLU programming? You will have much more work if you decide to RAM clear the machine. It is better to just edit the existing programming if you want to save time. The only thing that bugs people is the grand total and that can usually be turned off anyway. See what you think
Cash register doesn't register that I have scanned a barcode. The scanner beeps and sends the data, but nothing happens on the register (SE S300)
Has this scanner been working on the register previously, or is this a new setup?
If anyone needs a Casio SE-S300 manual, try here: http://the-checkout-tech.com/manuals/cashregisters/Casio_SE-S300_users_and_programming_manual.html
1helpful
I need to change the date on casio cash register SE-5300 that has been set wrong
I Suppose that is Casio SE-S300 Model :
To change Date,
1. Key turn to PGM
2. Press [1] [Subtotal]
3. Input today's date, eg : 8 March 2010
Press [1] [0] [0] [3] [0] [8]
4. Press [X/Date/Time]
5. Key turn back to REG
6. O.K.
Grand Canyon Tech
Grand Canyon Tech
