Question about Ipcw Chevrolet S10 / S-pu 1998 1999 2000 2001 2002 2003 2004 Head Lamps Projector Clear Chevy Only-1 Pair
Auto wiring diagram
I put a cab from a 20001 chevy s10 on a 2000 s10.The motors where different so the end going into the engine module a different. can I splice the end from the 2000 4.6 onto the 2001 2.2 color to color
Posted by roger riggle on
Robert McCall
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 51 Answers
Absolutely not. You'll need to either map out the wire harnesses from the two vehicles or swap the harnesses. Either way you will also need the computer from the engine you are installing.
I’m happy to help further over the phone at https://www.6ya.com/expert/robert_24775b73ca70da93
Posted on Aug 30, 2014
Can you show me a wiring diagram for 2001 chevy cavalier 2.2,4cyl engine
Eng light on = go to Autozone or Advance or someplace like that. They will read the code/s for you free.
Start by checking your fuses. You really have to look to find all the different diagrams. You can get an alldata subscription for just one car at a low price which should give you all the info you want. I have found the wiper motor connector and the shift solenoid wiring diagrams.
Jun 30, 2015 | 2001 Chevrolet Cavalier
I do not need the wiring diagram for a car. I have
if your just reconnecting the starter wires the terminals are different sizes and the wire eyelets are different sizes to match up with the terminals.
Sep 28, 2014 | Cars & Trucks
Will a chrysler engine go into a chevy truck
It would certainly be much easier to stay with a GM drive train.
Everything the Chrysler setup touches would need to be modified.
Wiring, exhaust, cooling, even the driveshaft. And that work would make the truck worth much less than if it had a stock drive train.
Jan 27, 2014 | Cars & Trucks
When I turn on the lights I blow the fuse for the tail lights , dash lights, side lights and horn. I've changed bulbs , disconnected tail lights , traced wire looking for ground,disconnected lighter and it...
You might have a short in the headlight switch itself. I would check the positive side of the taillights to see if they are shorted to ground. Not sure on a manual, besides All-Data.com. You can also purchase it thru Auto Zone.com.
May 01, 2010 | 1992 Dodge Ram 150 Club Cab
Can you put a steering column from a 1997 c/k 1500 chevy truck in a 1994 c/k 1500 chevy truck? I am putting the motor (4.3 V6) from a 1997 c/k 1500 chevy truck into a 1994 c/k 1500 chevy truck. I need...
pick up a chilton book from chapters indago and check the diagrams they might be similar but i believe the wiring is a lot different '
it is likely you will need both manules
Jan 08, 2010 | Chevrolet Chevy Cars & Trucks
Engine swap. color codes are different need wiring diagram
I've done several of these swaps that sound good at the time but end up being a Huge problem.I would start with the correct harness for the engine you've put in.It must include the under hood harness and what ever harness connects to it thru the firewall to the computer.You'll also need everything connected to the transmission to the computer including any thing connected with the brake and accelerator pedals.Next get the wiring diagrams from Jeep or buy the Chilton or Haynes manual,they have the diagrams included.Get the harnesses connected to the engine,trans and computer,then work backward towards hooking up everything else.I really feel your pain,I've put 20 year newer engines in older cars,V-8's where 6's were,an olds V-8 where a in-line six was(ford),Late model v-8 in a 59' Chevy.All these were simple compared to what your going thru.Please contact me if I can be of any help?
Sep 28, 2009 | 1991 Jeep Cherokee Limited
Looking for under hood wiring diagrams for 1980 chevy van c10 with a 350cid engine
go to kragen or any other local auto parts store and buy the repair manual for your car it should have the diagram and everything else you need to know about your car there very handy to have
May 13, 2009 | Chevrolet Chevy Cars & Trucks
2007 Chevy Express Trailer Wiring
Go to an auto parts store and see if you can have a look at some electric brake modulators and trailer connectors they almost always have instructions in them that detail standard colors for any install. The standard diagram is often right on the back of the connector package.
Mar 14, 2009 | 2007 Chevrolet Express Passenger
Ipcw Chevrolet S10 / S-pu 1998 1999 2000 2001 2002 2003 2004 Head Lamps Projector Clear Chevy Only-1 Pair Logo
297 people viewed this question
Top Ipcw Office Equipment & Supplies Experts
 Russ Hill
Russ Hill
gbob59
Are you an Ipcw Office Equipment and Supply Expert? Answer questions, earn points and help others
