Question about Garden
Evinrude outboards what is he oil/fuel ratio mix
Levi Branch
    New Friend:
  • 37 Answers
Johnson and Evinrude carbureted 2-stroke outboards since 1964 require a 50:1 fuel to oil mixture (2%) on engines without an automatic oiling system - 6 gallons of gas to 1 pint of outboard oil.
Posted on Aug 30, 2014
4 Related Answers
Cleverer2
  • 298 Answers
SOURCE: oil mix ration for craftsman chain saw #358-356-8-
Should be on the cap. SEARS is the site but try here too:
http://www.managemyhome.com/mmh/products/ManualSearchDisplay.action?psid=54057012&sid=PaidSearchxGooglexManuals
Posted on Mar 26, 2009
J. Bradshaw
  • 121 Answers
SOURCE: I have a Mac 3214 chain saw and I do not have the mix ratio
40 to 1 is the ratio
Posted on Jul 11, 2009
VtToolMan
Mark
  • 704 Answers
SOURCE: mcculloch 310 oil mix ratio
The proper gas/oil ratio is 50:1, that is 50 parts gas, to one part (2) cycle oil.
If you plan on leaving gas in the tank when not being used, I always recommend adding some gas stabilizer, such as Sta-bil, which makes starting the chain saw easier regardless of how long the fuel mix has been sitting in the tank or saw (up to 2 years according to Sta-bil label)
Hope you find this Very Helpful and best regards!
Posted on Sep 09, 2009
FlyingLabRat
Dustin Reuber
  • 468 Answers
SOURCE: I need the gas mix oil ratio for the Poluan Pro 42...
40:1 gas to oil ratio.
Posted on May 28, 2010
WHATS THE FUEL AND OIL RATIO FOR 25HR 2CYL OUTBOARD MERCURY
need the year of manufacture as some 2 stroke units have oil injection that automatically mixes the oil in the correct ratio for engine rpms otherwise it is 50:1 ( 50 parts fuel to 1 part oil)
oil requirements --certified tc-w3 2 stroke outboard oil ---not ordinary engine oil
reference
google --type in mercury outboard oil to fuel ratio
May 07, 2017 | Mercury Boating
I have an Evinrude 7.5hp outboard motor.Mod# 8RC1A SN# 0178194. What Year of manufd? How to mix fuel & what octane fuel to use & what oil to use? Help me go fishing, thanks.
91 octane rating ( no e-mix fuels ) and proper outboard oil ( not normal engine oil)
outboard oil has a property that allows the oil residue to stick to the metal bits and helps prevent rust
e-mix fuels absorb moisture and and rusts out steel tanks , destroys rubber components and corrodes aluminium components
the model you have is not listed on any 7.5 hp engine from 1950 to 1958
model number starts at 4434 to 7512 to 7525 in 1958
for a better answer , talk with an evinrude service center who should have a chart listing your motor
units with oil injection are 50: 1 ratio and others are 6 gallons to 1 pint of oil which is around 45:1
I would seek advice from an evinrude service center for the correct fuel to oil ratio for your engine
to mix the fuel , put the oil in first then the flow from the bowser will effectively mix it up to start with
then fit the cap on the tank and shake it up yourself
Apr 20, 2017 | Boating
I have a 1998 model E25RMECA I NEED TO KNOW WHAT TYPE GAS TO USE IN IT. AND IF IT IS 2 CYCLE OR 4CYCLE.
I found a mixture of sites for the information
one owner of a 1998 25 hp evinrude says that it is a 2 stroke with a fuel mix ratio of 50:1 as 25:1 is a bit smokey
another site says that the recommended octane fuel rating is 87 although it might run better on 91
best advice is to find an evinrude service dealer and get the right information as the later 25 hp units are etec engine which will be 4 strokes
Oct 23, 2015 | Clymer Evinrude/Johnson 5-70 Hp...
Evinrude year serial number 3014-10340
3014 is a three horse 1955 Evinrude Lightwin. 16/1 fuel oil mix, points set at 0.020 and the NGK B6S plugs set at 0.030". 80-90W marine grade gear oil is used in the gearcase. Nice motors!
Aug 20, 2014 | Sierra International 18-5199 Marine...
What is the oil to gas ratio in my 4 horse Evinrude< Model # E4BRHCOB Ser # B101702
50:1 since the late 60's
Too much oil will gum up the rings, smoke too much and foul plugs. Use ONLY major outboard manufacturers oil, Mercury, Yamaha, Johnson/Evinrude TCW-3. They work the best, and no alcohol fuel.
Jul 11, 2014 | Sierra International 18-3090 Marine...
Fuel mix ratio for outboards
Go to
Nissan outboard manuals
Download the manual for your engine.
Jun 11, 2014 | Boating
120 evinrude 2 stroke runs rich
what 2stroke oil you using and mix ratio ? Quicksilver outboard oil is best and 50:1 mix ! send a picture of your carbs , side views and intake with airbox cover off !
Sep 21, 2012 | Clymer EvinrudeJohnson Outboard Shop...
Oil weight to use for 1989 evinrude 2 stroke 90 hp outboard motor
The oil is mixed with the gas, just buy 2 cycle engine oil and follow ratio mixture
Sep 29, 2009 | Boating
What is the correct fuel/oil mix for evinrude 4hp ?
the proper mix is 50 to 1 or 16 oz to every 6 gallons,in my little boat I put 4 quarts in the 48 gal tank and its been running for 22 years,your running way to rich and your plug is probaly fouled,take it out clean it up/dump your fuel and mix it right,thats a great motor you got,I hunted with it for years,oh yeah when you get started run it till all the smoke is gone or you will have carb problems ,if you dont have them all ready,a little carb cleaner wont hurt but get it running first,or all that trash will foul you out,have a great trip bartriley1
Jan 04, 2009 | Boating
Garden Logo
573 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
