Roland Versa Art RS 640 64-inch Printer Logo
t
tchakoute rodrigue Posted on Aug 30, 2014
What can i do when my machine sow error code 0010 0010?
What is error code 0010
SOURCE: Error E000001 -0010. The error code is for the fixing assy not getting to the correct temperature in a specified time. The 0010 part of the code is indicating the copier was turned off and back on without resetting the error.Dec 25, 2009 http://www.fixya.com/support/t3708490-error_code_e000001_0010
How do I solve Error Code - E000716-0010 In Canon IR2870
Failure of the communication with the 2-way unit
Description
When the communication with the 2-way unit is faulty after detecting the connection with the finisher.
Remedy
1.Install the 2-way unit.
2.Check the cable.
3.Replace the DC Controller PCB (PCB4).
4.Replace the 2-way unit driver PCB.
1helpful
Motor error 0010
Estou com um erro na roland RS 640. Erro service call 0109!
F3-F100-0010
http://www.windowserrorhelps.com/error-f3-f100-0010-fix-toshiba-error-f3-f100-0010-the-simplest-way/
This website explains it well, along with a few options to fix it. Uses some computer jargon but is fairly easy to understand.
81helpful
5answers
10helpful
SCAN MOTOR ERROR CODE: 0010 0010
VERSA VP 540 MACHINE GOT WHILE RUNING SCAN MOTOR ERROR 0010 0010 PLSEASE GIVE ME SOLUTION FOR THAT. mY EMAIL ID
[email protected]
[email protected]
5helpful
3answers
Canon ir 7086 error code e00005-0010
give me the solusion of error code 225 of machine cannon 7086
reply plzzzzzzz
9helpful
Ir8500 error code e000020-0010?
you have to clear this error by doing the following press additional function(*) and 2,8 together) then press additional functions (*)again (you have to do this quickly to get into service mode then you press copier
then you press function
then you press clear
then you press ERR
then you press ok
then turn off the machine and then back on
this is a low toner level detection code
do you have a new toner in the machine?
43helpful
3answers
Error E000001 -0010
The error code is for the fixing assy not getting to the correct temperature in a specified time. The 0010 part of the code is indicating the copier was turned off and back on without resetting the error. To reset the code, Press the additional function button, then the numbers 2 and 8 at the same time and then the additional function key again. The display will now be indicating the service options available. Touch COPIER, then FUNCTION at the top of the display, the CLEAR in the middle, then ERR, then OK. Power down copier at the right side rear, then turn back on. If the error comes back then you will have to check the fuser assy to see if the front drive gear has failed or one of the thermistors has gone bad. Good luck
2helpful
3answers
I keep getting error codes
i am getting error E000001 -0010
Top Roland Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Roland Office Equipment and Supply Expert? Answer questions, earn points and help others
