i have problm that suzuki swift 2008 dosnot start in meter the sign of key blinking the code is p1610 andb1141 thanks.i have problm that suzuki swift 2008 dosnot start in meter the sign of key blinking the code is p1610 andb1141 thanks.
You can't post conmments that contain an email address.
Hello. Diagnostic code P1611 means you have low voltage at your relay box; code P1610 means someone kept starting that car 5+ times. Good luck and keep me informed; if you want to.
DTC P1610 Lost Communications with Body Multiple Control (BCM) System
Circuit Description
The PCM uses the serial data circuit to communicate with various other devices and systems in the vehicle. The PCM ensures that communication remains established by monitoring the serial data circuit for state of health messages from the other devices using the circuit. If the PCM detects a loss of the state of health serial data message from the Body Function Controller (BFC), DTC P1610 will be set.
Dont know where you found these fault codes but their not in my nissan list or the universal codes ,no my main suspect is the alternator diodes now charge the battery and then disconnect the alternator wires and see what happens when car is left for a few days
I had both p1610 and p1612 codes pop up today on me when my car decided to just die. i did a lot of trouble shooting and it led me to removing the negative battery terminal which resets the system and bam, car started right up.
these are codes for the anti theft system.did you use a key to start it other than one you usually use?if im not mistaken p1610 is a difference of key/unregistered key and 1614 means system entered lockout mode because of key.please let me know how you make out.
