Play in stering linkage
The most common of all problems in a steering system is excessive steering wheel play. Steering wheel play is normally caused by worn ball sockets, worn idler arm, or too much clearance in the steering gearbox. Typically, you shou Id not be able to turn the steering wheel more than 1 1/ 2 inches without causing the front wheels to move. If the steering wheel rotates excessively, a serious steering problem exists.
An effective way to check for play in the steering linkage or rack-and-pinion mechanism is by the dry-park test. With the full weight of the vehicle on the front wheels, have someone move the steering wheel from side to side while you examine the steering system for looseness. Start your inspection at the steering column shaft and work your way to the tie-rod ends. Ensure that the movement of one component causes an equal amount of movement of the adjoining component.
Watch for ball studs that wiggle in their sockets. With a rack-and-pinion steering system, squeeze the rubber boots and feel the inner tie rod to detect wear. If the tie rod moves sideways in relation to the rack, the socket is worn and should be replaced.
Another way of inspecting the steering system involves moving the steering components and front wheel BY HAND. With the steering wheel locked, raise the vehicle and place it on jack stands. Then force the front wheels right and left while checking for component looseness.
