Philips 42pfl3603d/f7
The power supply is at fault. Pull this board out. Find transformer (location) T701. On this transformer there is a pin. The location of this pin is EL41. With a small sharp screwdriver, scratch the area around pin EL41. Now, with a hot soldering iron, resolder this. There are no capacitors to replace. You have returned your TV to a good working unit. Thanks for listening, Matt of Martins TV.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
SOURCE: need help with TV calibration for philips
Try these,
Contrast: 53 Brightness: 56 Color: 45 Tint: 2 Sharpness: 2
Color temperature: Off
Dynamic contrast: Off
Digital Natural Motion: Off
DNR: Off
Color enhancement: Off
Active control: Off
SOURCE: 42PFL3603D/F7 PHILIPS HDTV
Your problem is a combination of calibration of your TV and signal strength of your Dish system. Proper color calibration will remove the motion blur and SD issues in the average home. If you continue to have poor quality on your dish system after calibration, then Dish needs to check your signal strengths again. (AND fix it.)
SOURCE: I have philips 42 inch 42pfl3603d/f7 and I get
These had issues with the power supply. Capacitors will "vent" causing voltages to run low.
SOURCE: Where can I buy an IR sensor board for a 42"
SHORT CAPACITOR ON IR BOARD NEAR CONECTOR FROM KEY BOARD ITS THE PROBLEM FOR REMOTE COMANDER NOT WORKING .
SOURCE: My remote has stopped working.
Hi:
The IR remote sensor in side of the television need replacing, this is the sensor that receives the commands from the remote and relays them to the microprocessor of the TV. Have the remote sensor replaced.
