There was a communication error with the receiving fax machine due to poor telephone line conditions. Solution
Set the receiving machine to receive at a slower transmission speed
If the session fails after sending several pages of a large document, resend the document as several smaller documents.
Retry the fax reception at a different time when
telephone line conditions have improved. Call the telephone provider if
line conditions fail to improve.
Sir/Ma'am these error are basically due the Communication error of Receiving/Remote Machines. But each error shows different meaning.If during fax you receive the Error 348 then it may be because of several reasons like:-
The remote machine failed to respond to a fax command from the local machine because the connection was interrupted. These errors can occur if the phone lines in the area to be faxed are old or there is noise,Other reasons can include power outages and other power-related problems.
When The call-waiting service can cause this error or the remote user pressed the Stop key while the reception was in progress.
You can solve the Error 348 by the following
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Disable ECM. Errors might still occur, and might result in a degraded image quality on the received page. However, the ability to send the entire document will be improved.
Try sending at a lower transmission speed.
If during fax you receive the Error 321 then it is because of:-
You can solve the Error 321 by the following:-
If during fax you receive the Error 358 then it is because of:-
The remote user pressed the Stop key, causing the session to be terminated.
The remote machine encountered a system problem such as no paper or a paper jam. This prevented the fax from receiving any more pages, and caused it to terminate the session prematurely.
The call-waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line.
The remote machine encountered an incompatible feature causing it to terminate the session.
You can solve the Error 358 by the following:-
Configure the remote machine for document reception by clearing any paper jams, loading sufficient paper, and clearing any other error messages.
Configure the local fax machine to use a slower reception speed.
Enable or disable the ECM setting.
I hope this solution helps you and you have clear picture in your mind. Let me know if you have any confusion in your mind Sir/Ma'am, Your Rating as Five Stars for this solution and Words of appreciation as Feedback for me will be really esteemed Thank You for taking my service Concerned: Muhammad Uzair Team : FixYa
Check your phone line by removing fax and plugging a normal handset into the line socket and then listen to line. If a line has noise on it, it will slow transmission down, it can also cause wiggly lines on transmitt and receive, if this is the case, it needs to be dealt with by your phone line provider, just report a noisy line
Having the machine set to fine in transmission settings can also cause slow faxs, and a dirty scanner glass can also cause receiver image to have marks on received image but it is normally marks down the page
Error code 322- There was a communication error with the receiving fax machine due to poor telephone line conditions. Solution
Error code 358--
Try
Disable ECM mode on your machine.
Try sending a fax to another location.
Try making a copy of something or printing a transmission report or journal from the "reports" menu. If the same problem is apparent on these printouts, then your drum unit or toner cartridge need to be replaced
Are the problem prints all from the same source? If so the problem could be on the transmission end. Can you connect to your fax and print to it from a local workstation? If so print several images with dark solid patterns and see if it is actually the printhead. Try printing in cyan, magenta, yellow, and black colors to to rule out each individual printhead.
