Question about Patio Heaters
Why won't my patio heater light
My patio heater pilot light will not stay lit
dgskroch
    New Friend:
  • 16 Answers
The thermocouple has to be in contact with the flame at all times when pilot is lit, this heats up and sends mill-volts back to the safety valve to keep the gas on, if not it won't let the gas through, otherwise you need to clean the pilot or replace the thermocouple if everything else is ok..
Posted on Sep 17, 2014
Hi i have a progaz heater the the pilot light won't stay on it starts the heater then flickers for a bit the go's out
Defective thermocouple. It is the metal tube that stays in the path of the pilot light flame.
3answers
Patio heater fell over and now not working could it be the flame screen needs to be replaced
????????????????????????? Whatevers Broken / Damaged needs replacing
Sahara big burn patio heater
From the Troubleshooting Guide - Check the Obvious Turn on the gas and listen at the burner to see if you can hear the gas arriving.
If the patio heater has an electronic ignition system make sure that there is a spark. If there is a spark but the heater will not light up, try using a lighter or burning spill to light the gas. Be ready for a flash over if you have been trying to light the gas for a while-there might be a small cloud of gas near the burner.
Start at the Bottom The most likely reason that a gas heater will not work is that there is no gas. Take out the empty gas cylinder and replace it with a full one. Often you will feel that there is still gas in an empty cylinder but there is not enough to create the pressure needed to drive the gas burner. An empty cylinder will feel light.
Check the Gas Regulator The gas regulator is the connection of the gas cylinder to the gas pipe that takes the gas up to the burner. Some regulators have a flip switch that prevents the valve in the top of the cylinder from being depressed-effectively an "off" switch. If there is such a switch, make sure that it is in the "on" position.
Check the Gas Pipe Although it is most unlikely that the gas pipe can get blocked, remove the gas pipe from the regulator and from the gas inlet at the top of the heater. This pipe is pressure fitted and held in place by pipe clips. Blow air through the pipe to ensure that it is clear.
Check the Burner The burner will be a very simple assembly. Take each part off in turn and check for any blockages. Also check that the burner apertures are set correctly. Beneath each burner is a small chamber in which air and gas are mixed. Make sure that the gas and air inlets are clear.
If Your Heater has a Pilot Light If your heater has a pilot light, there is the possibility that the thermo couple has failed. The thermo couple is usually shaped like an inverted "v" and sits in the flame of the pilot light. The temperature acts on the thermocouple to keep the gas supply to the burner open. A good indication that the thermocouple has broken down is that the pilot light goes out when you try to turn the heater on. Thermo couples are readily available patio heater parts and usually available from stock.
If you have carried out all the checks and the heater will still not light, you can repeat all the checks more slowly and carefully or take your heater to a specialist for a service.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/steven_7f54ab9063554f66
1helpful
Patio Heater Garden Sun model JDS04SS After lighting the jets all lightup but within minutes only half the jets stay alight. Is this dangerous? the heater is a couple of years old.Can it be repaired and...
Your heater needs to be cleaned & adjusted. Contact your gas supplier for information, as to do they do the service or have someone they recommend. You will probably have to bring it in.
Pilot light bright yellow
Need to clean or replace it,supply tanks is empty, low pressure,bad regulator, not enough air supply etc. Kinked supply lines.?
1helpful
Heater pilot light will not stay lit
The thermocouple is either too far from the pilot flame or is bad.
My fahrenheat fuh-54b won't stay running long enough to heat
Most likely defective thermostat or heat sensors on the unit
1helpful
No Flame
It could be dirty nozzle or dirty line
Unscrew every thing in the nozzle and control valve section and clean gas line and reinstall and try it
2answers
My pro temp dual propane burner heater will light but won't stay lit
Either the temperature probe (at the pilot light) that signals the gas valve to open is defective or the gas valve is.
Eden pure beeps 3 times, and then it will not work
Sometimes things can get out of sync. Try unplugging the machine for a few hours to rest the code on the board.
Patio Heaters Logo
Top Patio Heaters Experts
deton8 von Splosion
Tom Chichester
Jerry Kramer
Jerry Kramer
Are you a Patio Heater Expert? Answer questions, earn points and help others
