Question about Brisk Air Dometic A/C Roof Top Air Conditioner Upper Unit 15,000 BTU 459516.XX1C0
Can you recharge. a dometic a/c rooftop unit serial number 991762724
Unit seems to run ok but will not cool
Stephen Brisbois
  • 44 Answers
No service ports on the unit. It needs to have a service port soldered to it and the system breached before you can check / charge.
Posted on Aug 30, 2014
Dometic B57915
Unsure if that is a refrigerator or an Air Conditioner.
Please add information to your question as to the model, or whatever you can tell.
Jul 13, 2018 | Dometic Rooftop RV Air Conditioner
My Dometic roof top ac doesn't cool. Fan runs fine, no COOL air. With thermostat in off position. Checking the voltages I found 118v at the breaker. At the run relay, 118v going in and a coupl
Please reply with Model number of bottom of AC unit ( upper) . Can be seen from inside usually. Thermostat model, plus if controls are at the ceiling assy or at thermostat on wall.
Jan 17, 2013 | Dometic Rooftop RV Air Conditioner
Hi my Dometic rooftop (1999) used very little worked perfect untill this past year when we went camping. Fan worked ok, but no cold air coming out of ducts. Compressor seems to kick on, or at least a...
Check compressor run amps is correct with a ampere meter. If less, it's under gas leak. Keep your arm on discharge line (smaller pipeline). If no heat means no gas in the system. Find leak and arrest it. Vacuum and recharge gas.Better service the unit and check. Due to condenser & cooling coil, air filter, blower wheel are dust blocked will result to very less or no cooling. Helpful?
Jan 31, 2011 | Dometic Rooftop RV Air Conditioner
I have my dometic Rooftop ac unit. The heatstrip/fan run perfectly but when I turn on the ac...the fan runs good but when the compressor kicks on it just hums.
The compressor coming on does make a slight "humming" sound which is normal. Is the unit cooling properly? Do you think it is louder than before?
May 09, 2010 | Dometic Rooftop RV Air Conditioner
My RV AC unit was runs good on high cool last night but this morning it was only running on low fan(some what cooling it Seems)What should I check first. thermostat,fan ???
low medium high speed of fan iscontroled by selector switch on the thermostat or recheck the thermostat if ok check control wirnig from thermostat to the fan relay on control borad and from relay to the motor.
Sep 03, 2009 | Dometic Rooftop RV Air Conditioner
Open Questions:
My GE window AC Model#AEL06LXQ1 Serial#AM311149P I forgot to add my question. The AC is only a year old/young. It is properly installed in a basement window with ample space outside in the window well which is fully open to the air above the window well is only covered with a window mesh type screen which keeps clean & filters out debris only. Last year around this time it was cooling the entire room nicely however displaying e8 error code intermittently which was a problem. GE refused to advise via phone and set an appt. for a tech. to come over. I did some research and reset, unplugged, waited etc. I have a dedicated electrical outlet for the AC as well. I really do not recall what I did but the unit stopped error coding e8 altogether and worked wonderfully for the rest of the hot season. I cancelled the GE tech. Now this year I am having same problem. Unplugging, waiting, changing settings, resetting to default settings, I have tried everything and to no avail. The AC will run for a while with the compressor in check and cool down the apartment but it doesn't last long, approx. 45 minutes, at best with one or 2 times exception where it held cool overnight. I don't know what to do at this point. I am not too tech-savvy. I also am unable to lift this ac out of the window. I've a back injury and though a relatively small unit, it's too heavy. Please advise. I hope you have an easy fix solution. The user manual doesn't even list the error codes! I have spent hours searching youtube videos and haven't found a solution. Hoping it's as simple as manipulation a setting. Thank you.
Jul 03, 2020 | GE Heating & Cooling
See all Brisk Air Dometic A/C Roof Top Air Conditioner Questions
Brisk Air Dometic A/C Roof Top Air Conditioner Upper Unit 15,000 BTU 459516.XX1C0 Logo
732 people viewed this question
Top Brisk Air Heating & Cooling Experts
Paul Carew
Marvin
Marvin
Are you a Brisk Air Heating and Cooling Expert? Answer questions, earn points and help others
