Radio Communications Logo
A
Anonymous Posted on Aug 29, 2014
Electrical schetmatic electrical diagram and mic plug in pin sequence
  • Mechanic688
    Mechanic688 Dec 21, 2014
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
James Walker
Level 2:
Habit-Forming:
New Friend:
  • Expert 65 Answers
  • Posted on Mar 10, 2015
James Walker
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
65
Questions
0
Helped
27507
Points
126
1 Related Answer
Anonymous
  • 126 Answers
  • Posted on Jun 02, 2009
SOURCE: turner Rk 56 mic
Here is the wiring information for a Turner RK56. If the picture is too samll for you too see or it does not load up, email me at [email protected] with the subject as RK56 wiring diagram needed, and I will email it to you.
Dean Pitts
Rollin CBs
CB Uniden 4-wire mic to a Uniden 510 radio how to wire color codes please
look up microphone wiring diagram for your cb and mic. more than one way to wire, depending on mic and cb having 4 or 5 on plug end. write down mic numbers and cb plug numbers. if audio on mic is 3 and cb is 4 put 3 on 4 pin check each wire. using power mic make sure red and black wire are on the right pin, can damage radio or mic or both.
Wire 4 pin Turner Plus 3 Power Mic for cb radio to 5 pin President Washington SSB AM Radio
the best i can find is this
red pin 5 ptt
black pin 4 ptt ground
white pin 1 mic
shield pin 2 mic ground
no connection pic 3
Heil icm plug wiring diagram
The Heil "ICM" microphone is designed to be used with certain Icom brand ham radios. These have a 8-pin round plug. Describing the pinout to you will depend upon your perspective, whether you are looking at it from the microphone plug itself, or the microphone socket on the front of the radio. Therefore, from the perspective of looking at the mic plug on the end of the mic cable, note that there is a notch or dimple in the plug that also lines up with the screw. Going clockwise from the notch, the pins are numbered 1 thru 7. Pin #8 is the center pin.
Pin 1 = mic input
Pin 5 = Push-to-talk (PTT)
Pin 6 = PTT ground
Pin 7= Mic ground
From the standpoint of an Icom transceiver, the remainder of the mic connector pins are as follows:
pin 2 = +8 volts DC (output from the radio)
pin 3 = frequency control up/down
pin 4 = squelch switch
pin 8 = audio output (level varies w/vol control)
Hope this helps
What is the wiring diagram for realistic 211173 mic to cobra 25ltd
first,a realistic plug is a 5 pin D.I.N. type and a cobra 25 is a 4 pin screw on . If you are trying to save $$ by using an old mic then let me say that you can get them prewired real cheap.
95 Nissan Altima 4 pin electrical connector to the distributor.
You could potentially short circuit something, but most likely if it's wrong you'd blow a fuse. Google 95 Altima distributor connector and see if a picture shows the wire colors, and plug them back in matching the picture, or check ebay/amazon for a new one. Could be called Distributor connector, distributor wiring harness, distributor pigtail, distributor electrical connection, ect.
5helpful
2answers
4helpful
6answers
Mic wiring diagram
Same as Omega
#1 Mic Audio
#2 Receive
#3 Transmit
#4 Up/Down for channels
#5 Ground/Shield
#6 13 volt
Top Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Radio Communication Expert? Answer questions, earn points and help others
