GE GTWP1800DWW Top Load Washers Logo
A
Anonymous Posted on Aug 29, 2014
Why do i have a red blinking light on my motor when its in off position
The washer keeps spinning off balance when I removed the front cover I noticed a red blinking light on the motor pannel
gbob59
Level 3:
  • GE Master 3,063 Answers
  • Posted on Dec 22, 2014
gbob59
GE Master
Level 3:
Answers
3063
Questions
Helped
720457
Points
10420
Probably washer is smart enough to detect the out of balance.
Try to distribute the clothes in a balanced maner as soon as you detect it is out of balance.
5 Related Answers
A
Anonymous
  • Posted on Sep 09, 2007
SOURCE: G.E. spacemaker washer will not spin
It was the motor brake.
Anonymous
  • 1294 Answers
  • Posted on Nov 29, 2007
SOURCE: Whirlpool Duet Front Loading Washer Imbalance causing front door not to close
Plug off the wall, open the top of the machine, check to see if any wires have come loose in the door lock area, tighten up.
Anonymous
  • 136 Answers
  • Posted on Mar 18, 2008
SOURCE: Will not initiate spin cycling
try balancing machine
Anonymous
  • Posted on Jan 13, 2009
SOURCE: I have a GE front
I have a different suggestion based on my washer's similar problem. If the black stuff is powdery and localized at the back of the unit, more than likely the culprit is the drum pulley itself is warped, causing the belt to chafe against the drum. The black powder is rubber residue from the scraping of belt on plastic. No need to replace unit. New belt and new pulley run about $70 each.
Anonymous
  • 530 Answers
  • Posted on Dec 28, 2009
SOURCE: my front load washer keeps getting off balance no
if you have a kick panel take it off and check your shocks. one of them might be broken. Did you move recently?
Washer out ballance
Hi Joe
Check lower balance springs, remove front panel to view there are 6-8 of these, to gain access and remove the front cover, insert a knife or thin blade approx. 4" in the from each side in between the seam on the front panel, this will release the top cover clips and the top cover can be hinged up and back. undo the two top screws to remove the front panel. Also check drum is rotating at full speed when spinning, if not spinning at full speed check and replace drive belt.
When i click the button on the wiifit board to connect to the wii, it connects at a second. then loses connection and wii says it is lost. the button on the board just keeps flashing or goes off
If you haven't already tried to replace the batteries, do this (if you have, this is useful information to include in your problem description :D). If that hasn't worked, you may need to re-sync the board with your Wii.
1. Power on your Wii console (there is no need to power on your balance board at this time).
2. Open the SD card slot cover on the front face of your Wii to reveal the red Sync button on the Wii.
3. On the bottom of your balance board, remove the battery cover to reveal the red Sync button on the balance board.
4. Press the Sync button on the balance board (there is no need to keep it depressed; simply press and release). You will notice the power LED on the power button on the balance board blinking.
5. Now press (and release) the Sync button on the Wii console. After the LED stops blinking, the Sync is complete.
If this does not fix your balance board, it may need to be repaired or replaced. Contact Nintendo and provide warranty information if applicable.
3helpful
Washer will not spin or ajatate. I need to remove the front panel to see what up?
Use downwards force to relieve tension on the spring clips holding that front panel on.themobilian_1904.jpg
Video how to:
Once yall have the front panel removed yall will notice the motor has a green blinking light on it.
The motor blinks on and off all the time It blinks faster when running. That is normalment mon ami.
If it ain't acting right it will display flashes:
1 flash bad motor
2 flashes slipping belt
3 flashes corrupted software bad motor
4 flashes failed mode shift circuit
5 flashes little green men (bad motor)
6 flashes locked motor check for objects between tub
7 flashes bad lidswitch.
8 flashes motor overheated too much soap
9 flashes brake resister is toast bad motor.
To Reset the Inverter Board: Push the timer knob in so the washer is idle. Unplug the machine for one minute. Plug back in and raise and lower the lid six times within 12 seconds.
After resetting the inverter board, put the machine in a spin cycle and see if it runs. If not, check for a green blinking light on the inverter board. It will flash failure codes according to the picture above. If no light you probably have a blown fuse built into the neutral side of the harness on the white/red wire.themobilian_26.pngthemobilian_27.png
Service manual and more HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
2helpful
How do you sync the wii console and wii fit board
Put the Wii Fit game disc in the Wii and start the game. Then open the small SD Card slot cover on the front of the Wii console then remove the battery cover on the bottom of the Wii Balance Board. Press and release the SYNC button on the Wii Balance Board. The light on the board should start blinking. Afterwards press and release the red SYNC button on the Wii console while the light on the board is still blinking. The light on the balance board will stop blinking and stay on steady once the syncronization is successful.
6helpful
I can not re start my nintendo balance board,
1. Insert a Wii Balance Board compatible game disc in the Wii console.
2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game. Press the A Button to bypass the wrist strap screen.
3. Open the small SD Card slot cover on the front of the Wii console.
4. Remove the Battery Cover on the bottom of the Wii Balance Board.
5. Press and release the SYNC button on the Wii Balance Board. The blue light on the board will start blinking.
6. Press and release the red SYNC button on the Wii console while the blue light on the board is still blinking.
7. The blue light will stop blinking and stay on steady once the syncronization is complete
22helpful
2answers
My wii fit balance board keeps blinking but will not stay on. batteries are good. cant find my instruction book. what could be my problem????
follow this
  7. The blue light will stop blinking and stay on steady once the syncronization is complete.
1helpful
When washer is in spin cycle drum is out of balance.
REMOVE THE FRONT PANEL AND SEE IF ONE OF THE SPRINGS HAS BROKEN, COME OFF AND THE TENSION OF THE BELT OR THE TENSIONER PULLEY
My lg front load washer is blinking LE my lg front-load washer sometimes blinks LE and doesn't finish the cycle
LE codes are extensively covered in past Fix-Ya solutions, but are generally caused by only a handful of things. 1. the " Load Error " can be a very off balanced load. 2. excessive use of soap leads to too much suds, and thus drag on the inner tub. (use 1 tablespoon of HE soap max. per load) or 3. the Hall sensor (part number 6501KW2001A) has failed. The hall sensor is rather easy to replace, and is covered by a seven year part warranty. Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Snap new sensor on and reassemble. Usually takes under a half hour. On a difficulty scale of 1 - 10, it might rate a 4. This should be a Fix-Ya for your machine, and at basically no cost!
Hi, I have a 5yr old Amana Distinctions Super Capacity Plus top load washer, 2spd motor, 3.3 cu ft. I have taken off the front cover to expose the wash tub, because recently when the washer is in a spin...
sounds like a drain pump issue, not able to remove water quick enough before the centrifical force of tub spinning throws it over the top, remove the pump hoses and look for blockages
Top GE Washing Machines Experts
Virgil Watts
Mike Cairns
Mike Cairns
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
