Question about Motorola Mobility RAZR V3c Cellular Phone
Pairing to bluetooth
I got a new razrV3c phone and now need to pair my motorola bluetooth HS850 to it. I went to the connection menu on my phone and then held down the button on the bluetooth and open boom so the light would stay lit. My phone can not find the bluetooth. there is no listing in "look for devices" so i never get to the step where it asks to enter the code. what do i do
Posted by adonna on
  • Anonymous Feb 09, 2008
    cant pair with other mobile phones
  • Mike Horne
    Mike Horne Feb 11, 2008
    I have a problem pairing my cell phone to my bluetooth. I tried as the manuel says but my phone sontinues to keep scanning and device found: 0
Anonymous
  • 127 Answers
The V3C cant pair with other phones.. I have to hold my bluetooth head set on top of my phone to get it to pair sometimes and make sure the headset is in pairing mode
Posted on Mar 26, 2008
I have tried everything . My Motorola Hs850 will not connect. It keeps indicating that the connection failed
Firstly, make sure you have enabled Bluetooth on your phone or whatever device your using the headset with. The default setting off, so go into your phones set menu and enabled Bluetooth.
You'll then need to 'pair' the headset and phone.
1. Ensure the headset is turned off (indicator light not blinking).
2. Press and hold the Call E button for 4 or 5 seconds. The indicator light will initially flash, but continue to hold down the button until the indicator light is steadily lit.
If the indicator light is flashing or not steadily lit when releasing the button, repeat both steps 1 and 2. Hold the Call E button for 4 or 5 seconds.
3. Enable Bluetooth on your phone and get to 'search for devices' it should find the headset.
4. Select Motorola HS850
Select OK or Yes to pair your headset with your phone. Enter the passkey: 0000 Select OK. When your headset successfully pairs with your phone, the indicator light changes from steadily lit to flashing.
Hope this helps. Oh and make sure your phone actually supports the headset!
Jun 13, 2011 | Motorola Mobility HS850 Consumer Headset
Need instructions for connecting ear piece to iphone 4
Hi,to complete the look of a tech-savvy, iPhone-using individual, you must have a Bluetooth headset to accompany it. You can pair any Bluetooth headset with an iPhone. The Motorola HS850 is no exception to this. Both Motorola and Apple's Bluetooth set-up process is fast, so you'll be talking with people through your new Bluetooth on your iPhone in a matter of minutes.
Instructions
Charge the Motorola HS850 headset fully before attempting to pair. Usually, it takes two to three hours to charge the headset.
Press and hold the "Call" button (has a phone icon on it) on the headset for six to 10 seconds. The outside LED light will turn on indicating that the phone is in pairing mode.
Choose "Settings" on the iPhone homescreen.
Select "General," then "Bluetooth."
Select to turn Bluetooth on.
Wait for the phone to search for in-range devices.
Select theMotorola HS850 from the list of devices.
Enter the headset passkey to complete the pairing. By default this is "0000."
Have a nice day..
Feb 23, 2011 | Motorola Mobility HS850 Consumer Headset
Won't pair with Motorola HS850 headset
How to pair a Motorola HS850 bluetooth headset How to place a Motorola HS 850 bluetooth headset into paring mode:
  1. Close the boom to turn the unit off.
  2. Hold down the call button until the blue light comes on.
  3. While holding down the call button, swing the boom open.
The headset is now in pairing mode, and you can search for it using your phone. When it asks for a PIN, use 0000.
Apr 20, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Having problems pairing
Apr 12, 2009 | Motorola Mobility Universal Wireless...
I've lost my pairing code how can I get another on, or is there a
From the Motorola Website:
The default pin code or passkey for Motorola Bluetooth accessories products is 0000 and cannot be changed.
This should work for you, but if it doesn't you'll to contact Motorola
Dec 05, 2008 | Motorola Mobility HS850 Consumer Headset
Motorola bluetooth headset HS850
There are several possible reasons for this problem.
Try the following steps:
- Shut off the headset.
- Shut off bluetooth on your mobile phone and restart it.
- Now bring your headset in pairing mode. How to do this should be explained in the manual.
- go to something like "add new bluetooth device" on your phone. Something like that should be in the bluetooth menu.
- the phone should find the headset now. Pair the devices using pincode 0000. That's normally the code for headsets.
you can use the headset now.
If one of the steps gives problems, just ask. Then I will try and give some more specific help.
Please give some reaction also if this was helpful...
Ruud
Oct 31, 2008 | Motorola Mobility Universal Wireless...
Won't connect to cell
When you're in a call w/the headset paired to the phone, if you press the options menu on the phone, it should say "Switch to Phone". If it doesn't then you're paired, but not using the headset. If it shows "Switch to Headset", click that and you'll be good to go.
May 09, 2008 | Motorola Mobility HS850 Consumer Headset
Bluetooth
To all with problems with bluetooth pairing.when you push button to turn on bluetooth headset ,hold button until steady light stays lit,then put phone in pairing mode,when ask for passcode enter 0000,which is the standard code for pairing bluetooth.
Mar 27, 2008 | Motorola Mobility HS850 Consumer Headset
Pairing Motorola RAZR with the HS850
No, living outside of your cellular "home area" has nothing to do with the bluetooth pairing. You're problem is a common problem. Lots people have this problem you are not alone. So, here is what I suggest. 1. Make sure both the headset and the phone are fully charged. 2. Delete the "device" from your phone. I mean precisely that. Go into you cell phone's bluetooth settings and erase your "HS850" from it. 3. Try re-pairing it. Put the phone and the headset in pairing mode and allow it to sync. This should do it. I always works for me. You usually only need to pair once and every time you use the headset all you should have to do is connect it. I hope this works for you. Good Luck.
Aug 02, 2007 | Motorola Mobility HS850 Consumer Headset
Motorola Mobility RAZR V3c Cellular Phone Logo
256 people viewed this question
Top Motorola Mobility Cell Phones Experts
Vernon Taylor
Jeff
Harrie
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
