How do you reset your computer to factory settings when its a black screen
You can not reset your laptop If showing black screen.
Because I have been also face this type problem. I am sharing a link for this problem Hopefully this link solved your problem.
https://www.errorsdoc.com/black-screen/what-is-black-screen-error
You cannot. The black screen indicates that the computer has not booted up or that there is something wrong with the video circuits/screen. Black screen not uncommon when you have motherboard failure.
SOURCE: Black Screen
try booting from a cd like the reinstall cd for windows that came with the computer. when starting hit F12 to show 1 time boot menu; select cd drive; hit any key when asked to boot from cd. This will tell you if its a software or hard drive problem.
SOURCE: acer reinstall issue
Run the same procedure again and choose factory settings. It wd do so , unless the recovery partition got corrupted.
SOURCE: asus EEE PC 900A Linux- boot problem after downloading updates
Consider downloading a specific release of Ubuntu; eeebuntu. Download the ISO and then conenct an external DVD device to it, during the BIOS screen, choose the ESC button and boot from the external device.
This Ubuntu-specific group offers three kinds of ISO's (simple, super basic, and a loaded release), all of which allow all parts to work out of the box:
http://www.eeebuntu.org/
If this does not work, check the informal eeepc forums
http://forum.eeeuser.com/
Turn on your computer. Right away there will be a black screen. You can restore factory settings without a CD, too. This will reset your BIOS.Press F1 when the black screen appears; you will enter the setup configuration mode. You will be presented with a menu.Select Restore Factory Defaults. Your computer will do all the work for you. As with the CD, this process may take several hours.
