Question about Sharp MX-2700N Color Copier
How do I print to the MX-2700n?
I have attached my lap top to the photocopier that automatically installed it. However when I try to print to it I receive an error message. Can anyone tell me what I am I doing wrong.
Posted by kelley harris on
  • Brad Brown Aug 29, 2014
    Hi kelley harris, I want to help you with your question, but I need more information from you. What is the error? What operating system?
Ethan Marvick
    New Friend:
  • 71 Answers
If you are conecting directly you should be using a usb cable and you will need to install print drivers from sharp usa.
I’m happy to help further over the phone at https://www.6ya.com/expert/ethan_e84416e0b13809d2
Posted on Dec 31, 2014
5 Related Answers
Anonymous
  • 24 Answers
SOURCE: error code h4-01
P * C * enter sim 14 press copy key then CA. Machine should reboot. if problem re-occurs your thermostat in the fuser has tripped
Posted on Dec 01, 2008
Anonymous
  • 148 Answers
SOURCE: sharp mx 2700n how to go SP mode and i get error code h5.01
Use SIM14 to
cancel the trouble.
Entering the simulation mode
1) Copy mode key ON → Program key ON → Asterisk (*) key
ON → CLEAR key ON → Asterisk (*) key ON → Ready for input of a main code of simulation
enter 14
accpet yes clear..
machine should restart.
You may have to have a tech look into why this is jamming...
Hope that helps
Lbcoaster
Posted on Dec 28, 2008
Anonymous
  • 143 Answers
SOURCE: Sharp MX-2700N - Error Code - 'Call for Service E7 - 05'
E7 is only part of the code. It could be a hard drive problem, memory problem, laser problem, or a loose connection on one of the boards.
Posted on Aug 01, 2009
Adorjani Laszlo
  • 1316 Answers
SOURCE: What do it do to fix ''maintenance required Code: CA''
The service acces code C-0-0-C,or C - interupt key -0-interupt key.Acces the list of commands maintenance preset counter setting and set to a new value,or maintenance counter clear.
Posted on Aug 02, 2009
rezazadeh
abbas rezazadeh
  • 328 Answers
SOURCE: Sharp MX-2700N how can I clear maintenace code CA?
enter code 20-1 start
Posted on May 27, 2010
Unable to print and make photocopies
when you try to print does it come up with any error message?
or does it get sent to the print spooler and then lost in cyberspace?
or does it get to the printer and then the printer says no?
for the error message follow what it says so if the error is no connection check that the wires are attached. if it comes up with an error code look it up on the HP website.
if it gets lost in cyberspace try reinstalling the printer with an updated driver.
and finally if it says no go to run and type services.msc and scroll down the list till you see print spooler if it says it is stopped start it and try again, if it still doesn't work try updating the firmware
Jan 03, 2014 | HP LASERJET PRO M1132 MFP
Can you solve the problem for my lap top Toshiba satellite E105-S1402, I am not able to register my finger print on TrueSuite Access Manager Finger Print. The error message come "failed to open the sensor"
You can try to download and install the Fingerprint Utility here and check if you will receive the same error message.
Refine Search by: Your Operating System (Vista by Default)
All Categories: Security
Title: Toshiba Fingerprint Utility for Windows Vista / XP
Download and Install
If the reinstallation of this software does not help then the issue must be related to a corrupt Windows Vista files and in my opinion the usage of the Toshiba recovery CD should helps.
Thanks for using Fixya
Jul 29, 2010 | Toshiba Computers & Internet
Wrong cartridge message pops up and won't print because of it
Even with new cartridges sometimes the pc board that is attached to the cartridge can get dammage,replace the faulty cartridge.
Jan 07, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Len trying to help Carol in a panic trying to print her resume. The HP office jet 4315 All-in-one was printing and ran out of paper. Installed more paper and it wouldn't print. It's connected to an HP...
If you're in a hurry, save to disk or USB memory stick, and dash to Kinkos / Staples / Business Depot or any other copy center, to get it printed out.
If you've got time otherwise, shut printer off, then on, and try and print a test page using the buttons on the printer.
If successful, then proceed to the PC. Shut down, reboot, and check the printer status. If good, try to reprint.
Sep 16, 2008 | Office Equipment & Supplies
Brand new Canon MP210 wont print at all
Try going into Control Panel, Administrative Tools, Services and make sure that the print spooler is set to automatic.
Also make sure you have the latest drivers.
Click Here To Go To Canon Support
Sep 08, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Tri Colour cartridge inserted is not intended for use in this printer msg
Try to clean the print cartridge contact points with a good rubber eraser and clean the printer side cartridge contacts with good lint free cotton cloth. Then first insert Black cartridge and then colour cartridge. Use some more pressure while attaching the cartridges.
Apr 22, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP812C and/or Epson LX300+ dot matrix Printers installed to a HP V3431 lap top computer would not print.
Download the latest drivers from the manufacturer websites rather then relaying on the old cdroms - they are probarbly outdated and made for XP.
Oct 29, 2007 | HP DeskJet 812c InkJet Printer
Sharp MX-2700N Color Copier Logo
62 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
