Question about Brother PE-770 Embroidery Machine
My button needle won't release the needle
The needle is stuck the machine throws a message and when I push the needle button it barely moves and won't release the needle. The book says I need to change the needle.
Posted by Christina Bandy on
Pru prut
    New Friend:
    Problem Solver:
  • 16 Answers
I think you should consider a little oil if it's metal parts - it is a small spring that holds the needle in place
Posted on Aug 29, 2014
3 Related Answers
Anonymous
  • 66 Answers
SOURCE: I was given a brother
Hey RM check the bobbin area and see if the hook area has any thead cought in it you might have to remove the bobbin case to see it
Posted on Jan 30, 2009
Tally Girl
Tally Girl
  • 1134 Answers
SOURCE: just changed the needle on
Firstly check that needle has been placed into the needle holder the right way, ie flat shank to the back. If you look closely at the needle there is a cut away at the back called the "Scarf" and this must face to the back of the machine as the rotary hook swings through there and catches the thread to make each stitch.
Also, check needle is fully up into the housing.
There is some good trouble shooting tips and tricks on this website. http://www.sewusa.com/Sewing_Machine_Repair/Sewing%20Machine%20Troubleshooting.htm
So check needle is in the right way, check threading up is correct and thread is in the needle eye. If none of these resolve the issue, then it is possible you knocked the timing out when you broke the needle. Remember, never drag fabric as it is stitched, let the machine feed it, you just guide it. Dragging is a sure fire way to break a needle.
If timing is out, (you can see info on what this means on www.sewusa.com site too) then you probably need to take it for a service to address this issue.
Posted on Aug 01, 2011
SOURCE: brother Innovis2500d embroidery unit attached and error message comes up that the needle position button is down. The button is stuck.
it sounds like the machine needs to be serviced
Posted on May 04, 2012
My needle will not go up and down
hi Tamara.
you have not said the make or model.but try this.
Make sure the push your bobbin winder to the right then to the left and see if that solves the problem. Your Old Machine has a Clutch & It Needs to be Released. The Clutch is this little dial that is inside of the hand wheel. In older machines, it was used to wind the bobbin without the needle going up and down.17 Jul 2015
My Needle is Stuck! My Hand Wheel Won't Move ... - It's Just Sewing
you could also go to this link and see if it helps.when you go to this link if a small windows open in the middle just close that little window.
My Needle is Stuck My Hand Wheel Won Move HELP It Just Sewing
The needle threader is stuckdown how do I release it
If the threader is stuck in the needle, try removing the needle from the needle clamp. If that doesn't work, take the machine to an authorized dealer for that make of sewing machines.
1helpful
2answers
What could cause the motor to turn but the needle doesnt move?
it's possible that the sewing machine may need a adjustment or a part could be broken, the machine should be checked
1helpful
The hook race wont stay in place in my babylock Grace
Make sure brace that holds hook is locked, bobbin is pushed in til you hear it click and hand turn machine and if you hear it hit any metal, machine timing is out, let me know...thanks
Release stop motion knob won't move
What are you calling a stop motion knob? Are you trying to stop the needle from moving while winding a bobbin?
Elna Carina won't zigzag
The machine's needle arm is not swinging left and right correctly, do I understand your problem correctly? I assume that you have the stitch selector set to zig zag, stitch length dial to 2 (green zone on the dial) and stitch width set to 4 to select a zig zag stitch. Needle up, push the needle bar to the right of the machine. Push above the needle thumb screw, dont push onto the needle itself. Pull the bar to the right, then release. It should return smoothly to the middle position. If you set the width to four and push the needle bar to the right, there is a spring that returns it to the middle, if this is not happening then good chance the needle bar cradle is seized up and the spring cant move it. You will need to take off the top of the machine and get some oil down the needle bar into the bearings, then apply pressure to the side of the needle bar, push to the right side to free up the bar movement. triflow oil is best and a means to deliver a drop or two down deep inside. I dabbed oil onto the needle bar with cotton swap stick on my machine that had this problem. You should be able to see a horizontal metal tube down there above the needle, the needle bar slides back and forwards on this but machines left can seize up due to dust, and dry old oil forming gunk on the moving parts. you need to lubricate and get it sliding freely again, you should be able to free it up with a bit of time, oil and gentle movement. mine took a couple of days to get it moving freely fully, it would give it a wiggle, dab of triflow oil, leave it, then have another go. I got triflow from a bicycle eshop on ebay, great stuff. Hope this helps you with your Carina, if not, post again and I'll try to help
1helpful
My Singer 5050 sewing machine won't let me
sounds like a part is damaged or jamed, the machine needs to be checked
to see what's wrong with it
1helpful
2answers
Needle won't move
I had that problem too! I usually turn the tension knob and it works,
Brother PE-770 Embroidery Machine Logo
Top Brother Sewing Machines Experts
Richard
Richard
Level 1 Expert
Paul Bade
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
