Where can I get a Fisher and Pykel Soft Touch dishwasher operating manual?
Https://www.google.com/search?q=Fisher+and+Pykel+Soft+Touch+dishwasher+operating+manual&rlz=1C1GGGE_enUS385US385&oq=Fisher+and+Pykel+Soft+Touch+dishwasher+operating+manual&aqs=chrome..69i57.92066j0j7&sourceid=chrome&es_sm=122&ie=UTF-8
Fisher and Pykel Soft Touch dishwasher operating manual Google Search
SOURCE: dishwasher f1 problem on fisher paykel
All the information that I have found about this particular problem indicates that the "F1" error is a flood or overflow alarm. It's generally caused by a clog in the drain line and/or tub not sealing properly when closed.
If this is a drawer style dishwasher there is a lid in the equipment cabinet that must seat properly on the drawer when it is closed. If you place items in the dishwasher that are too tall for the drawer lid to seat properly, it will not seal and water will splash over the sides of the tub during the wash cycle.
Another common problem is a clogged or kinked drain line. Remove the drain hose and make sure it is not plugged. Check it at BOTH ends.
The alarm is activated by a float switch in the bottom tray of the dishwasher. Look to see if this is any standing water in the bottom tray. If there is any water, or signs of wetness, the alarm will not clear until it is dried out. I found a couple of recommendations to clear the alarm. The first involved removing the dishwasher from where it is installed and tilting it at a 45 degree angle to pour any standing water out. Another method is to dry the bottom out with towels as best you can, and then use a hair dryer to dry any residual water. I hope I'm on the right track with this and I hope this solves your problem. Post back if you have any further questions.
CAUTION: UNPLUG the dishwasher or turn off the breaker BEFORE servicing inside the cabinet.
SOURCE: How to reset my fisher and paykel dishwasher
you have to remove the bottom drawer and remove the water from the base.theres two push in tabs on the bottom sides dd603 or if its a dd602/601 theres plugs that pull out remove them and the front panel the drawer will lift out far enough to get access.but you may find its leaking.hope this helps.
SOURCE: I have a Fisher Paykel dishwasher with water in top drawer
You need a Air gap kit designed by Fisher and Paykel to address this problem. It is pricey but it is worthy. I used this and very happy with it since no back flow problem from one while other running. Here is a link to order it.http://www.fisherpaykelparts.net/product/WT50/WT50-Dual-Air-Gap-Kit/
SOURCE: Fisher and Paykel dishwasher DD603 manual
You can get the manual below for free..
http://www.fisherpaykel.com/admin/pdfs/pdf_usecares/527971B_DD_user_guide_USw.pdf
Good Luck and please rate 4 thumbs for the free answer
