Question about Frigidaire Refrigerators
How to read model number FFHS2611LW?
There seem to be 4or 5 different model numbers for the 26cu.ft side by side.
Frigidaire
  • Official Brand Answer
  • 2,267 Answers
Hello friend, thanks for the post!
Please help me understand the question you are asking. Is there something specific you are searching for within the model number? Or are you referring to four or five appliances having the same model number? I look forward to your response. -Matt
Posted on Sep 03, 2014
3 Related Answers
Ronald Walls
  • 98 Answers
SOURCE: Given this Frigidare side by side, ice and
Sometimes they put the info in where the motor is. Don't know why. Guess it is so easy to get to ha ha. That may not be it but worth the look. Good Luck!!
Posted on Jun 06, 2009
Anonymous
  • 44 Answers
That O on the end is actually a ZERO ---0. You will be find something after you change that.
BarrettDenCo
Barrett Palumbo
  • 1772 Answers
SOURCE: my amana refrigerator model number ASD2620HRR,
42434
Sorry to hear about your problem.
Your main control card is defective. and or your compressor is causing the card to fail, or the card is trying to start the compressor.
You will need to call a service company to resolve your issue.
Since I tried to help you, please help me and rate/vote this response. Thanks and good luck.
If you live in the Denver,Co area I can help you.
Posted on Dec 23, 2010
What is the cubic feet of Kenmore refrigarator model #253.562824on and also need mearsurements of outside.
You seem to be missing a few digits in the model number. Sears Parts Direct lists 11 refrigerator models that start 253.562824. (The full models numbers have 2 extra characters, including 253.56282400 and 253.5628240N.) See http://www.searspartsdirect.com/model/search.html?q=253.562824 for the list of models.
Kenmore uses the 3rd digit after the decimal point to indicate the cubic footage of their refrigerators. With a 2 in that position, this model has a 22 cubic feet capacity (probably 21.6 or 22.1 cubic feet before rounding). Using the size of other models, the external dimensions will be between 30" W x 31-3/4" D x 69" H (the size of a 21 cu. ft. model) and 35-5/8" W x 28-1/4" D x 69-3/8" H (23 cu. ft. model). One current Frigidaire 22 cubic foot side by side model has the external dimensions: 33" W x 32" D x 69-7/8" H. (Note: the 253 in the model number indicates a product made by Frigidaire for the Kenmore line.) Unfortunately, I can't find the dimensions for any of 253.562824 models.
I hope this helps.
Aug 30, 2016 | Kenmore Refrigerators
1997 Nissan pickup 2.4 head torque sequence
From repair manual for 1996 KA24E 2.4L engine:
Number bolts as follows:
Exhaust side, front to rear - 8, 6, 1, 3, 9
Intake side, front to rear - 10, 4, 2, 5, 7
Tighten bolts in numbered sequence, five steps.
Step 1 - 22 ft-lbs
Step 2 - 58 ft-lbs
Step 3 - loosen all bolts completely
Step 4 - 22 ft-lbs
Step 5 - 54-61 ft-lbs
Oct 19, 2014 | 1997 Nissan Pickup
I have a Samsung side-by-side 26.1 cu ft,with the clear view icemaker, stainless steel. I believe the model number isRS267TD. Our digital display is just showing 0F. It seems to be working fine except...
When the refrigerator is powered on, the display goes through a self-test and then all the sensors are checked. In case there is a malfunction, an error code is displayed on the display. If there is no error, the display would stay off until you open the door or trigger the display.
Ask Samsung customer service toll free number.
Aug 01, 2017 | Samsung 26.1 Cu. Ft. Side-by-Side...
My amana refrigerator model number ASD2620HRR, 26cu ft is making a buzzing noise and has stop getting cold
42434
Dec 23, 2010 | Amana ASD2522WEB (25.1 cu. ft.) Side by...
We owne a side by side refrigerator the ice canister is broken &the mo tor does not work.can you sell it to me? Maytag 26cu/ft.sidebyside model#MSD2655HES Serial#10901487EC I just want to know if you...
no, you have a good Maytag, you need to go ahead and buy the ice canister from either fox appliance or sears parts or go online to repair clinic and give them your model number.
Aug 23, 2009 | Maytag Refrigerators
Samsung control panel says cold but fridge is warm
have you checked to see if the interior blower fans are working?
I'm not a tech, but it seems to be my problem
Aug 17, 2009 | Samsung 26.0 Cu. Ft. Side-by-Side...
Given this Frigidare side by side, ice and water. Lable inside says it's 19.8 cu ft with measurements of 32 x 33 x 67. Model number MRS20WRGWO. I can't find anything on this machine. The Frigidare model...
Jun 06, 2009 | Frigidaire FRS26H5AS Side by Side...
Buzzing sound clicks on and off from underneath fridge
that would be your relay going bad it will stop the fridge all together change it to a 3 and 1 relay
Apr 15, 2009 | Admiral 26 cu. ft. Side-By-Side...
Refrigerators Logo
67 people viewed this question
Top Frigidaire Refrigerators Experts
john h
jdthefixer
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
