Oster microwave model ogf41101 all works but dont heat found blown fuse that gose to the magnetron but cant read the size of fuse thats what i need fuse size
SOURCE: Oster 1.1.cu.ft countertop microwave model
check the high voltage fuse on the inside of the unit if this is not showing a fault then you would most likely be looking at replacing the magnetron in your unit this is the most common piece beside the fuse that shorts out and is what is directly realted to what is actually heating your food depending on what type of microwave it is it may be cheaper to just buy another microwave if the place of origin on the microwave came from a walmart or target store where as buying a magnetron may cost you between 50-100 dollars which is about the price of a micro wave at one of these stores if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to continue helping others in similar situations Thanks Rick
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off.
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if contact is not through the microwave will not work.
Now keeping clear of the microwave, switch on, use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues, you can use the microwave safely
