Why s my Verizon router extender flashing red constantly and not working?
SOURCE: GT704-WG with Verizon firmware
For those with the Verizon version of the firmware wanting to setup a Slingbox... You can go to the Security tab and then go to the Games tab and setup the 5001 port from there. It works.
SOURCE: Westell 327 wireless router
I found a solution for this problem. After complaining to Verizon Tech support, I finally got someone to listen. I talked to a Tech that I think was in India, nice lady that walked me through all the line test and finally a modem test. My connection keep dropping through the modem test, which I had a feeling the real problem was. I was told the modem was out of warranty and would cost $59.00 to replace at first, but after calling in so many times this lady sent me a new modem, not a 327W, a 7500. Disconnected the old modem, installed the new one and so far no more dropped connection problem.
SOURCE: Actiontec GT 704 WG Verizon to Frontier
You will have to contact Frontier and give them the Mac address of the equipment and they will tell you if it will work or not ( and they will also need to put it in their system)
SOURCE: Verizon DSL Internet connection intermittant Westell 327
verizon dsl westell 7500 internet light goes off 2 to 3 times daily
SOURCE: Unable to get verizon westell modem/router to work
Try this:
Go to the interface through your browser: 192.168.1.1
Go to profile editor, if there is a profile listed, click edit. Then enter in your username under Account ID and then your password. Hit save, then OK.
Then hover over the configuration menu option, click on advanced WAN. It should look like the following attached screen shot to this message. If the VPI/VCI and Protocol are different, which they probably are, click the edit button. Make sure it matches exactly as it appears above. VPI=8, VCI=35, Protocol=PPPoE.
If you have any more questions or this did not fix your problem, just come back here and leave a comment - I'm happy to help.
