Question about Casio G-Shock GW300CA-1V Wrist Watch
Synconization will not work
Since the time change my watch will not sync either manually or automatically. I have tried different locations, different times, all with no luck.
Posted by William Frohlich on
  • dibs2 Mar 03, 2008
    because Feb. was a 29 day month, clock is off and I can't re-set days/date.
    Can it be done?
  • adapaw Apr 03, 2009
    Hello, I received Casio GW300 2608 from USA. I live in Poland and sync is not working. It shows 1,2,3 signal level but all the time sync is ending with ERR. My seller from USA says that it should work in Poland because all of wave modules has Europe frequency. Has anyone any idea how to make sync working properly? I just could add that I got in home two clocks with atomic sync and they work very good.
    Thanks in advance.
Graeme Ross
  • 1,512 Answers
Here a user manual for the operation and Atomic synchronization feature of the watch. It does not work everywhere, and only in some countries. JAPAN, GERMANY, UK, and AMERICA
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2931.pdf
hope this helps. :)
regards
Graeme
Posted on Feb 14, 2008
How do I set the time and how do I get a user manual.
1. set time/datepush the pusher at 4:00 for couple second to start setting mode.pusher at 4:00 is to select time/date, pusher at 2:00 is to adjust time/date
2. if off sync between analog and digital clock happen. You need to resyn
step 1: follow the instruction 1 to set digital clock to 12:00.
step 2 : push and hold both pushers at 2:00 and 4:00 for couple second until it shows sync mode.
step 3: once it enter sync mode, you can use pushers at 2:00 and 4:00 to adjust the analog time to 12:00 same as digital.
step 4: push the pusher at 3:00 to exit the sync mode.
step 5: follow the instruction 1 to adjust digital time to correct time. Analog time will adjust it automatically.
Jun 18, 2011 | ESQ 07301132 Aerodyne watch
I just bought this watch but can't figure out how to set: time, date, and alarm. Please help. Thank you
2. if off sync between analog and digital clock happen. You need to resynstep 1: follow the instruction 1 to set digital clock to 12:00.step 2 : push and hold both pushers at 2:00 and 4:00 for couple second until it shows sync modestep 3: once it enter sync mode, you can use pushers at 2:00 and 4:00 to adjust the analog time to 12:00 same as digital.step 4: push the pusher at 3:00 to exit the sync mode. step 5: follow the instruction 1 to adjust digital time to correct time. Analog time will adjust it automatically.
Jan 14, 2011 | ESQ 07301132 Aerodyne watch
I HAVE A CASIO 3054 WAVE CEPTOR WV-58A WATCH. It
I tried putting your module number in (3054) and was able to download the instructions.
Try the following link http://ftp.casio.co.jp/pub/world_manual/wat/en/qw3054.pdf . This was successful in finding the manual you require.
Good luck and a happy new year.
Nov 05, 2009 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Can't adjust the date on a digital watch
These are the instructions for the AD0721. They might apply to your model, too. I hope this helps:
http://img261.imageshack.us/img261/6784/manualr.jpg
The analog setting of the watch takes place by pulling out the knob (kind of tough) and adjusting, like a regular analog watch. The analog and digital displays are will NOT stay in sync, unfortunately.
Good luck.
PC
May 26, 2009 | Watches
I purchased a Nat. Geo. Dakota watch in past fall..It was impossible to set. Paid a watch shop to set it....now it won't change to daylight savings time...nor will it change time zones when I travel....
When changing time zones, your watch must be manually set for the new time zone you will be entering. This watch is not designed to adjust for new time zones automatically. Instructions for changing time zones can be changed using the directions found on pages 2-4 in your instruction manual. When changing to and from DST, your watch should automatically adjust for this difference with the next 24 hours after the change. If your watch has not adjusted, you may be in an area that is not receiving signal. Check if your watch has received signal by using the directions found on page 1 of your instruction manual. If your watch has received signal in the past and no longer is receiving signal, your watch may need to be serviced or exchanged. Please contact Dakota Watch Company Customer Service by email at [email protected], or by phone at 1-888-459-0404.
Mar 08, 2009 | Dakota 2786-6 Wristwatch
Reset the time on my Casio GW300
When out of broadcast range for a time signal, the online manual procedure works for me: http://www2.casio.co.jp/manual_pdf/wat/en/pdf_search.php?MODULE=2608&submit.x=39&submit.y=11
Jan 03, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
Casio Wave ceptor
Check to see if the watch is set up to get its time from another country. You may find that the fault started with a battery change or an all reset of the watch. The default location for many of these models is for North America or Asia. In some models the location is not active until it is set. In different parts of the world, they are using different time set protocols. There are some technical reasons for this.
Check the instructions about setting the time zone for the watch. Pay particular attention to the time zone setting, location setting, and that the feature is turned on in the first place.
Jerry G.
Apr 08, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Daylight Saving Time will not set correctly
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
If you don't have a pdf reader you can get one from
http://www.foxitsoftware.com/pdf/rd_intro.php
Nov 08, 2007 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Casio G-Shock GW300CA-1V Wrist Watch Logo
165 people viewed this question
Top Casio Watches Experts
Janelle Schoonover
Janelle Schoonover
Ekse
Bruce Robin
Are you a Casio Watch Expert? Answer questions, earn points and help others
