The string keeps unwinding when running and wraps around the cylinder where the replacement spool is suppose to lock in. Where is the white lever located
SOURCE: 18v cordless string trimmer will not stop feeding line
Some of the trimmers recommend a certain size line, if you have one of these that let line out as needed, the speed at which the trimmer cuts will let out line as needed. If you have too small of line the drag for the friction let-out you will spoll all the line out. Make sure the line is the right size, They come in alot of sizes, anywhere from .060" to .125" line thickness so make sure you have the right size line!
SOURCE: grasshogXP string trimmer GH1000-ca type 2 7.2 amps
You can order replacement parts from:
http://www.toolpartsdirect.com/cgi-bin/noframes.cgi/blackdecker/CST2000_TYPE_1
SOURCE: corded black and decker trimer
Please check your line diameter. If you are using stronger line than specified in the manual, it could be the root cause.
SOURCE: Replacing the string on trimmer
I don't think you have to get the housing off for replacing the spool purpose. Usually, take the spool cover first, and then you will be able to take the spool out of spool housing.
SOURCE: How do you Replace string on the trimmer head spool
Take the spool off and turn it up side down take out the centre and wind the left side 6 times to the left and the right side 6 turns to the right then put the ends through the holes and refit to stud and screw on butter fly nut...
Dont try winding them both the same way as when you try to get more out 1 side will come out and the other will go inside so you will be back were you started
