Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Kenmore ice dispenser switch does not work can it be replaced?
5 Related Answers
Anonymous
  • 100 Answers
SOURCE: Kenmore Refrigerator stopped dispensing water
Either your water tank in the fridge froze up, the waterline that goes up the freezer door from the bottom hinge froze, or the switch that your glass hits is damaged. Do you hear any humming or noises when you put your glass up to get water?
Posted on Oct 30, 2007
Anonymous
  • 146 Answers
SOURCE: Kenmore elite (106.53606202) ice maker will not dispense ice
When you push the ice dispensing lever, you should be able to hear the micro-switch clicking. If no click, the switch is faulty. The auger motor which is activated by the lever could also be faulty. This is the motor that causes the auger in the ice bucket to rotate one way for crushed ice and the other way for cubes. The auger could also be jammed. Try switching between crushed and cubes to unjam the auger. Empty the ice bucket and start again.
Posted on Nov 03, 2007
Anonymous
  • 8 Answers
SOURCE: Kenmore side by side
take out ice bin, make sure you get it lined up when put back together, should click,sometimes they are a little off and you have to keep trying, mine has that defect, it works, but only on its terms, its a pain to do, but that can stop it from working due to a safety thing
Posted on Nov 08, 2007
larryyb
Larry Youngblood
  • 291 Answers
SOURCE: Water dispenser in the door is dispensing water very very slow.
check and see if the ice is fully formed or look hollow / if hollow then run you a new water line to frig / if cubes are full then replace water valve.
Posted on Nov 26, 2008
Anonymous
  • 14 Answers
SOURCE: Replacing the Ice dispenser motor on Kenmore elite refrigerator?
There is a small door under neath ice maker shelf (literally) w/ 2 small screws that keep it in place,or a button that can release ice maker on the rt. side of machine. Good luck!!
Posted on Apr 04, 2009
Kenmore coldspot refrigerator model 52552100 makes ice but wont dispense it
Below is a fix by another owner of your make and model for the same issue.
Pulled out ice bucket; tried ice dispenser with door latch pressed in and solenoid engaged and motor moved. Tried again and nothing (couple of times). Tried water...all good...good closure of dispensor flap (air pot operated). Opened dispenser (pried off carefully from bottom on this unit not to take off the glued part) and saw the micro-switch broken off of the ice dispenser side. Checked micro-switch (all good). Replaced control bracket...all good to go.
Nov 25, 2016 | Kenmore Refrigerators
The ice dispenser is not dispensing ice. When you put a cup under dispenser and push in, nothing happens. Its a Kenmore Elite, model 106.5896*701
here are some places to look, check the dispenser switch is working and also that it is being activated by the mechanizm, check that the auger is turning, if not is the motor getting power but not working? is the selector switch in the correct position and is it making contact...
Aug 22, 2011 | Kenmore Side by Side Refrigerator
Kenmore Elite refrigerator ice and water dispensers not working
check for a child lockout button it will look like a tiny padlock ,press and hold for 3 sec.(could be the freezer door light switch)
Jul 24, 2009 | Refrigerators
Ice Maker Dispenser Motor Won't Stop Running
There is a plastic part in the dispenser that holds the micro switch that operates the auger motor when you push the paddle. If you're handy with hand tools, you can order the part and replace it yourself. The part is on the outside of the door.
Jun 15, 2017 | Kenmore Refrigerators
Kenmore Ice Maker
Sounds like a water valve problem to me. Force the ice maker to cycle. (turn it off and let it get cold for at least an hour then turn it back on). Test for voltage on the ice maker side of the valve. The valve is usually in the back near the floor. Just follow the water line. Another solution. switch the wires on the water valve. then try the water dispenser and see if it makes the ice maker fill up. See if when the ice maker cycles water comes out the door. If the ice maker causes water in the door , replace the valve, If door switch causes ice maker to fill up replace ice maker again.
Jun 27, 2008 | Freezers
check the mirco-switches behind the panel at the dispenser section. basically, when you depress the lever for water or ice, those levers make contact with a switch, and the switch turns on the ice dispenser motor. if the lever is pushed too hard, the switch can be knocked out of position. I had to re-position my ice switch with some duct tape.
Feb 16, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
No water from dispenser
chances are dispenser board is bad check power going in the board should be 120 volts and power out if no power out replace board
Dec 17, 2007 | Kenmore 25.1 cu. ft. Side-By-Side...
Nov 02, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Oct 30, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
No ice through dispenser
When you operate the ice dispenser lever, you should be able to hear a little click from a micro-switch that then switches the auger motor and the light on and also opens the flap. If you cannot hear this small click, then the micro-switch is faulty. The ice dispenser only works when the freezer door is closed, so you could also inspect the door light/fan switch for proper operation.
Oct 30, 2007 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
200 people viewed this question
Top Kenmore Refrigerators Experts
gbob59
Dale Copeland
Dale Copeland
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
