Hi I have a service code 7402:0004230 on my Kyocera printer fs-c5100dn what does that mean please
SOURCE: error code on kyocera fs-3800 printer
E1: xxxxxxxx = Main motor error
Either the motor aint turning or it is being stopped from turning...Usally drum or developer units cant turn, or main motor or control board stuffed...
below is stuff from service manual and ....my comments
Suggested causes
The main motor is overloaded. Overcurrent in the main motor circuitry due to an excessive torque....... Check Drum, developer unit, toner cartridge and process units ensuring free movement
• Connector insertion error........check developer plug is secure (left top near toner cart little plug)
• Defective gate array U204 on the engine
board (KP-864). .......replace board
• Defective harness between engine board and
engine relay board (KP-760). .........secure replace cable
• Defective harness between engine relay board
(KP-760) and main motor.
SOURCE: kyocera fs 3900dn printer
It needs a firmware update, very common, it would most likely be under warranty, if not post email so I can give you the firmware update required and I will instruct you on how to upload it to your quality printer.
SOURCE: Can you help me with kyocera fs-1030d
If a paper jam occurs while printing, the printer notifies it by the following combination of the four indicators. Remove the
jammed paper . After removal, open and close the top cover once to initialize the jam sensing
SOURCE: What does mean Kyocera FS-3900DN Call Service 7410:0020192 ?
take out your paper tray... drum and developer and then pull out the paper
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
SOURCE: How to scan from Kyocera
There is a send button on the left of the control panel. after pressing send, use address book, and chose where to send to....obviously your address book must be setup first
