Question about Konica Minolta Bizhub Press C6000 Copier
Bizhub pro c6000
After changing developing unit (C,K) drum unit (C,M,Y,K) developer (C,M,Y,K) charging corona (C,M,Y,K) the error code c-2823 appear on starting up (on gamma adjust) the output of the 4 colors on test pattern NO:53 are good
Posted by bachir abou zeid on
Konica Minolta Error Codes and Solutions
  • 210 Answers
Did you made all the steps from the service manual when you changed the drums and developers?
Posted on Aug 31, 2014
  • bachir abou zeid
    bachir abou zeid Sep 04, 2014
    I use ORUM unit replacement procedure
  • bachir abou zeid
5 Related Answers
firecontrol7
Norman J Weimar Jr
  • 6958 Answers
SOURCE: Bizhub 420 Photocopier
Have you check the Printer control board. Also does the toner bottle turn? You can force it in 47 Mode. to turn the bottle motor CW or CCW
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Aug 04, 2009
Giamma Giamma
  • 12 Answers
SOURCE: Our bizhub-250 receives a C2557
hi,
open and close front door cover to reset error.
If it persists you have to execute (TCR Toner SUPPLY)
Tell me if you need to execute it.
Bye.
Posted on Mar 20, 2009
Bubbabear64
Tim Babcock
  • 2794 Answers
SOURCE: Yellow dosent work ok
Theres a service code to run the calibration program to reset the colors. It should be ran by a technician because that machine is very picky about running the procedure the right way. If someone shortcuts it, it makes a big mess.
With three error codes on the screen, it won't be something easy on your end to clear it.
Posted on Aug 17, 2008
SOURCE: error c2557 konica minolta 250/NEC IT2530
Reset it, start it with the right door open, go to service mode, clear the counters for drum and developer and go to functions menu. Close the right door and start immediately the F8 function. It should work.
Posted on Aug 23, 2009
SOURCE: Our bizhub-250 receives a C2557, need help with service mode
Utility/Counter -> Details -> [STOP][0][0][STOP][0][1]
Go to counter and clear the life of the developer and drums and then run F8 from functions.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Posted on Sep 03, 2009
Error c2814
The proper value cannot be figured out within the specified time by the correction of the patch density correction /K. Or, the proper value of the developing DC output is 0 or lower.
Associated Parts:
• Printer control board
(PRCB)
• Developing unit /K
• IDC sensor (IDCS)
• IDC shutter solenoid
(SD3)
Remove the black (K) Drum. behind and toward the front is a silver/chrome looking thin bar with a tine square that square is a sensor clean it or replace the drum (switch different color see if changes codes) or switch out sensor with a different one each drum has one when was the last developer was replaced for black getting close to a PM???
Jul 12, 2015 | Konica Minolta Bizhub Press C6000 Copier
Por que impressora konica minolta bizhub c6000 apresenta error 2703
Check the Cyan Charge Corona housing. Remove it and reseat it. IF not that check the HV board. and or connection at the back of the drum and transfer middle assy.
Oct 16, 2014 | Konica Minolta Bizhub Press C6000 Copier
Bizhub pro c6000
Check that all of the charge wire assy.'s are properly pushed in all the way in particular the cyan also ensure that the bolt at the top of the middle section is tight not just the one on the left side when closing the upper middle section housing drums and transfer belt.
Aug 28, 2014 | Konica Minolta Bizhub Press C6000 Copier
Konica minolta continuous printing
Have you had the developers and drums replaced or does the screen say Replace PC Drums? There are certain house chores the copier does before "Ready to Copy" it is waiting for them to get done, so that equals "Please Wait". One big item is making sure the developer and toner are properly mixed inside the developing units next to the drums. Did you recently replace the drums and the developer if so did you clear the counters for the drums and developer, FIRST? IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developers and a new drums and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the drums unit replace the developer. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. .
Apr 11, 2014 | Konica Minolta Bizhub Press C6000 Copier
How do I change the drum on a bizhub 3510
First ensure fax line and and network cable is disconnected (If no FAX or network dont worry) dont want any print jobs or faxs arriving before you run Developer and drum checks after replaceing both.. Second go to the service mode and clear the drum and developer counters touch end then power off the using main power switch left hand side rear. You will be replacing both do not just replace the drum. Ensure your drum comes with what is called a drum cleaning blade, along with your developer. Secondly open the right side door and remove the Image unit. Dissamabley the image unit four silver screws two per side. Then pull each side apart from the base and lift up. T change developer remove the 3 alummin screws fro the base top. Then dump the old developer DO NOT USE A VACUUM CLEANER THE STATIC ELECTRICITY WILL DESTROY THE SENSOR AT THE BOTTOM OF THE DEVELOPER UNIT!!!!!!!!!! Turn the gears on the side so that large roller that runs along th\e front of the developer unit turns downward. keep turing it unit all of the old developer is out. DO NOT USE WATER OR WET RAGS to cleanup use a brush. Add your new developer. One Bag only. Reassamable. Now for the Drum. Remove both side covers one side has small plasitic been so be careful. Reove drum remove three screws to remove old cleaning blade this section you can use a vacuum clean turn the gears to get the hold section clean. install the new cleaning blade and drum DO NOT TOUCH THE DRUM use only the side gears. Replace the SCTRON Grid and Charge Corona UNIT. REassaembly Image Unit.Then POwer up the machine, Enter service mode and run Fuction F8. Do not may copies or prints before this or you will have to buy new developer again.
IF YOU REALLY WANT TO DO THIS?????? HAVE SERVICE TECH COME OUT AND DO THIS
Jan 17, 2014 | Minolta Di3510f Bizhub Copier
What part of the machine is affected in error code C2557 of Konica Minolta bizhub 350
Sir/Mam, Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure/Developer Charge, and make sure the counters where cleared. Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST? IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8/Developer Charge. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
Jan 16, 2014 | Konica Minolta bizhub C250 All-In-One...
My copier displayed error code c2557. How do i fix it
Jan 16, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Error code C-2421
Check you your yellow developer unit, last time the developer was changed, or bad sensor on the under body of the yellow developer unit, worse case bad main board$$$$$$$$$$$$$$$$$
Nov 13, 2013 | Konica Minolta Bizhub Press C6000 Copier
How to change the drum cartdrige.
Remove the imaging unit ,remove the charge corona assy,remove the OPC drum,remove 2 screw and dump the developer out.Reinstall the imaging unit ,pull out the toner cartridge and push in toner cartride ocation the developer cartridge.Turn on the copier and wait then the copier perform the new developer initialization.Whwn the Start button in ready(green light),change the developer cartridge to toner cartridge.
Mar 05, 2013 | Minolta EP1031/1031F CS/PRO Copier
C-2813 error code in c-6000 help us
2813...related to cyan.
Excess charge on drum beyond the specified value.
Solutions...1) swap the drps board with yellow or with other color unit and see weather code is changing .if it is changing the drps board is the culprit.
2) clean the HV contacts located behind the processor unit.
3)clean the IDC Sensor unit
4)change developer
5)caronas
Oct 27, 2012 | Konica Minolta Konica Kit For Bizhub Press...
Konica Minolta Bizhub Press C6000 Copier Logo
448 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
