How does one remove toner smearing on the right and left side printed pages for a HP 2055dn laser printer?
SOURCE: toner marks down right side of page
hmmm...sounds like your toner cartridge is truly unhappy. I'd return it if I were you.
no worries..start by getting new driver for that here
SOURCE: laser printer not printing properly
Since you have changed the tone cartridges ...and it still does the same....
the next step is to check the transfer belt..transfer roller(this when hit by laser light stores the image and runs on the powder ink..the parts that have been created by the laser on the transfer belt is where the powder sticks)......remover the transfer belt roller and check to verify that its not worn out..its in the form of plastic paper more like Teflon.....view to see that it doesn't have severe markings...if its marked you will need to change the transfer belt to
If this doesn't fix the problem than you will need to change the laser scanner unit....
so basically its your cartridge...that provides color powder dust for image....
transferbelt...that transfers the image to the paper with the image being created by the laser scanner and the cartridge providing color
the last process is fussing ...heat is used to make stick the powder to the paper..and is done by the fusser unit...
as for your case the image is not either created by the scanner itself in the right manner..or the image is not properly created coz the transfer belt is worn out....
I suggest you replace the transfer belt next.
cheers!
SOURCE: Printing quality off? 2550 HP laser jet?
When installing new cartridges, it's always a great idea to perform a cleaning and recalibration of the machine. Below are the steps needed to do just such a task. You may want to print these out or save them somewhere for future reference as well. They are directly from the HP website.
Please rate the tip accordingly and thanks for using Fixya.com.
Cleaning the printer
Calibrating the printer
There are two methods of calibrating the printer manual: at the printer or from the Toolbox on the computer.
From the printer
Turn the printer off and then on again.
From the HP Color LaserJet 1500 or 2500 Toolbox on the computer
From the HP Color LaserJet 2550 Toolbox on the computer
SOURCE: HP Laser Jet 4700n-Light printing on right side of
Try shacking the toner or tap it on it side. Toner might not be even at cartridge. Then you can do a full calibration( You can find it at print quality), do this twice. First full calibration checks for errors, second calibration fix it. Also check if fuser isn't dirty at right side.
SOURCE: Hp laser jet printer p2015d printing blank pages
the plastic actuator on the main door is probably broken so it doesnt actuate the shutter door for the laser thus creating blank pages
