As soon as unit is switched on i see, "hello" then "please wait" and tv screen shows message "bootloader:0.3" and "hardware: 0xb060" "searching for software" later "update failed"
SOURCE: Firmware update failed RD-XS34Su
If it was a toshiba supplied disk, then I should follow up with them with the failure, as it was their fix, that caused this problem, they should replace/repair this unit for you
SOURCE: RCA DRC8030N Problem
hey maybe you can try this first before the other solution posted i just read..
Open it up and unjack the drive unit from the maid board. it hould be connected via a cable.. turn the unit on and it should display an error message or error code.. Once this is done unplug the unit and reconnect the cable this should reset the unit and it should work..
I have never tried anoter drive before in any unit cause i could never get it to work, i always purchased the exact replacement parts.. In your case i believe its cause the main controller is damaged or frozen.. If you got a battery n the board remove it wiat a few minutes and replace it this should reset the unit..
SOURCE: DEAR SIR my LG rh-2252
some dvd recorders take a while to come on if you turn it on with no disc in and wait for it to load up also check that the cables are all in correctly and you are on the correct channel it should show a start up screen also try changing the channel through the dvd recorder if this does not work and you have read through the manual contact the manufacturer or supplier
SOURCE: Panasonic DMR-ES15 DVD recorder startup failure
The unit failed during self check, probably the power regulation board. A check by a qualified TV/VCR repair person is in order.
SOURCE: My LG BD300 worked the other night and today it
how long have you been using this player? I suspect the laser (lens) of the player. I think the laser (lens) is weak that's why it cannot read data/files on DVD discs.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or a mechanism problem.
Get a lens cleaner, use it
to clean the lens. If that doesn't solve the problem, get a screw
driver, open the player's cover so that you can gain access to the lens,
use a cotton board to clean the surface of the lens. This should clean
dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To
replace the lens, remove the bad laser, use it as a sample to get
exactly the same type and do the replacement. Note that replacing a
laser (lens) needs a professional touch, so if you cannot replace the
laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Good luck.
