Onida 21 xcite ultraslim sound problem
When start a tv in morning tv sound is lost then slowly slowly its come so please tell me what is the problem?
jukeymart
    Champion:
  • 239 Answers
Faulty capacitors in the audio section
Posted on Aug 28, 2014
5 Related Answers
Rossiel Gomez
  • 517 Answers
SOURCE: I have 21 in onida
Good day!!!!
That problem is cause of loose solder connection on the board of your TV...
Here are the step by step guides on how to solve your problem:
  1. Open the back side of your TV.
  2. Get soldering Iron and soldering lead.
  3. look for the CRT board.
  4. Resolder the board especially the power supply section and the ply-back pin.
  5. Then try to open it (power on) the TV.
  6. Also try to hit the TV again and observe if there is any other improvement or reactions.If there is any reaction on the TV it means that there are still a loose board.Try to check and resolder it again.
Thank you!!!I hope this solution could be helpful..
Posted on Aug 11, 2011
Ambari
  • 901 Answers
SOURCE: i have onida t v 21
Looks to be power supply problem. contact authorised service center for economical repairs.
Posted on Apr 29, 2010
Anonymous
  • 108 Answers
SOURCE: my onida 21 FGL Tv
its the problem due to the blue-back mode. check for any loose contacts of AV cables, it could also be due to dry solder
Posted on Jul 29, 2010
caroldon
  • 17130 Answers
SOURCE: my onida 21" black color
Possible there is a fault in soldering. Poor joints in the CRT base circuit of the CRT tube will result in poor connection after some use due to the fact the heating and cooling will detach off the leads. So use a good soldering iron to touch up all the points in your main board and the CRT board and it must work provided your tube is not faulty.
Posted on Feb 07, 2011
jeisankas-19
SOURCE: DARK PICTURE ON ONIDA COLOUR TV
only for audio but after without vedio
Posted on Jun 01, 2012
I have a JVC model HD-52G886 tv. that loses sound.
Replace or have replaced the Audio board in the set----a lot of them fail.
Mar 12, 2012 | JVC HD-52G786 52" Rear Projection HDTV
PUT IN NEW BULB EVENTUALLY GOT A PICTURE LAST NIT RESET BULB LIFE GOT UP THIS MORNING STARTED OFF WITH A PICTURE SLOWLY STARTED TO LOSE PICTURE AND NOW JUST LINES DOWN THE SCREEN NO PICTURE
try to rest the tv by unplug from outlet press power hold it them reconnect power cord while you hold the power buttom on tv for 30 seconds them release and do the same with cable box.
Dec 12, 2010 | LG RE44SZ20RD 44" TV
Buzzing sound while tv is starting up. now the buzzing sound is happening while the tv is on the whole time
Hi, If your TV came with a Manual . Please read the first 3 pages it will tell you about precautions
where to place and set-up panel. If you have lost your manual look it up on internet.(Google) is one
popular search engine. My Guess is that you may have humming coming from (Floresent lights and/or other equipment).
Nov 15, 2010 | Televison & Video
When i try to turn my plasma tv on in the morning i now have to turn it on multiple times. Once it's on and warmed up it turns on and off ok and the screen looks fine. going back to turning it on once it...
It sounds like you have failing capacitors in the power supply. It would be best to have a technician to look at it or locate a power supply for the TV and replace it.
Aug 28, 2010 | Akai PDP5073TM 50 in. Plasma Television
Lost all gears while driving this morning
Definately has too be the Problem. There are Marks on there, They may be really Faint though. Get some fluid in there if it is low and hope that it will not need to be Rebuild.
Jan 18, 2009 | 2001 Chevrolet S-10
MY MX5 MR1 1991 MODEL , SLOWLY LOST POWER WHILST DRIVING!!!
It sounds like your alternator.Have it checked most places will do this for free.
Nov 19, 2008 | 1991 Mazda MX-5
Video channel has diagonal lines
check the connections from your video to your tv, sounds like you have a loose wire,
If not re-tune your tv , it might have lost the tuning a bit , but its probably a loose connection
Feb 28, 2008 | Televison & Video
Crashing sound on Protron 32 TV
no sound, everything was working fine the night before. woke up the next morning, and turned the tv on, and there was no sound at all. nothing from the TV, DVD, and nothing from the Computer. Please help. [email protected].
Dec 26, 2007 | Protron PLTV-32 Television
Televison & Video Logo
122 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
