Where is sending unit for outside temp gage located ? How do I trouble shoot it?
SOURCE: 96 jeep cherokee
If it worked before, maybe a bad/wrong sending unit. Check the connection also.
SOURCE: the temp gage and the oil presser gage dont work on my 1990 wrang
Normally it's on the thermostat housing at the front of the engine.(I have also seen some models with a second sensor on the l/r of the cylinder head) but the therm housing is best bet!!!
SOURCE: coolant and temp sensor location
4.0 sometimes has one on left rear of cyl head Usually the front one does both ...goes to computer, then to fan relay then fan.
SOURCE: electical trouble shooting
Your solution is simple,1998 Jeep Cherokee. The ASD relay gives power to the fuel pump the injectors and distributor also the Oxygen sensor heater circuit. 1st check the fuel pump fuse make sure its not open. If it is open you are dealing with a short to power located at the Oxygen heater circuit,these wire are prone to short together you may have to open the wiring harness and make the inspection if power steering fluid or transmission fluid has degraded the wires you will have to solve for the fluid leaking to protect the harness(wires) from shorting
