This washer is brand new. I got one load out of it, now it will not fill. It will drain and spin. It has a water level sensor, so will not agitate because it will not fill. I have one cold water hose attached, the hot water side is plugged with a pipe cap. I only wash in cold water.
You may need to use a Y adapter to feed pressure to both inlets to get the machine to fill. If it senses no pressure on one inlet it wont fill. You can run both inlets to on source. Since you did not post the model number it is hard to say. Some machines also test the water temp to see if it is warm enough to start or it needs to preheat.
Posted on Mar 05, 2018
SOURCE: GE Profile WPRE6100G Top Load Washer
The most likely cause of your problem is the lid switch.
Posted on Oct 27, 2008
SOURCE: agitator grinds and won't spin
remove cap,,or fabric softner dispencer..pull straight up..look down in the agitator you will see a plastic cover,,pull it straight up...now your looking at the agitator dog cam assmbly..thats a 1/2 in nut there,,remove it you will need a nut driver or wrectet...now just pull the hold agitator up...be careful not to lose the agatitor dogs..onthejob
Posted on Jan 17, 2009
SOURCE: GE washer won't fill with cold water
Cold water pipe had become frozen. FYI this model of washer has a nice feature whereas you can test each component i.e. valves, by setting the timer and reading the LED's on the front panel. Instructions are in the schematic.
Posted on Jan 19, 2009
SOURCE: Kenmore 80 series top load washing machine won't agitate or spin
defective motor coupling,,replace..onthejob
Posted on Jan 24, 2009
SOURCE: My Whirlpool washer won't agitate or spin . But it does drain the water.
i also had the same problem, and it ended up being the coupler. It was not hard to replace, it cost me about 19.00. I didn't follow full recomende instructions. I tipped the washer backwards. Removed the drain pump and the motor itself. Then I removed the old coupling and placed the new one. The washer is working like new...
Posted on Jun 02, 2009
Hello Greg Aguilar - Are the house valves turn on fully? Washer not filling with water can be caused by many reasons. Most common cause is a faulty switch that doesn't allow the value inside turn or a kinked fill hose. Other possibilities can be water valve faults, faulty control board, pressure switch or wiring failure. Since you have just recently purchased the washer, I strongly suggestion contacting the manufacturer for a listing of certified techs that can move forward accurately.
Dec 09, 2012 | GE WBSR3140DW Top Load Washer
Sep 10, 2011 | GE WDSR2080D Top Load Washer
Mar 23, 2011 | GE WBSR3140DW Top Load Washer
Jan 07, 2011 | GE Profile WPRE6150K Top Load Washer
Jun 15, 2010 | GE WBSR3140DW Top Load Washer
Jan 17, 2010 | GE WBSR3140DW Top Load Washer
Oct 02, 2009 | Maytag Centennial 3.2 cu. ft. SuperSize...
Sep 08, 2009 | GE Washing Machines
May 20, 2009 | GE WBSE3120B Top Load Washer
Jan 17, 2009 | GE Profile WPRE6100G Top Load Washer
43 people viewed this question
