Question about SHIMANO AMERICAN CORPORATION Sienna 1000 Front Drag Spinning Reel
Untangling a shimano sienna 1000
How to untangle or re-spool manually
I cannot find an anti reverse switch on a shimano sienna 1000 spinning reel....is it me or is there no switch?
The anti-reverse lever is under the body, right against the spool..its recessed a little to keep it out of the way and prevent accidental "switching".. I added a diagram...its number 8978
Shimano SN 1000FD Sienna FD Spinning Reel Parts
please mark as helpful.. thanks
Jul 27, 2017 | Fishing
How to untangle window cable in 2000 buick lesabre passenger front door?
I have never done your year Buick, but if it is a metal cable I did help a friend with a BMW that had that system. I have a 1992 LeSabre service manual and it tells you to replace the assembly (typical GM solution)
I the cable is tangled, and kinked, it will fail again even if you get it back together. Again if it is like the BMW, there is a spool that the motor drives. the cable comes to that spool from two directions and each end winds in the opposite direction. So when one cable is wrapping on the spool, the other cable is unwinding, when you reverse directions, the cable does the same.
Hope this helps, have you done an internet search?
Jun 11, 2014 | 2000 Buick LeSabre
How to untangle letters to make words in Jumble Word Puzzle
Hello, You are going to have too use dictionary, google, or yahoo to help with untangling words.
May 26, 2014 | Video Game Consoles & Games
Tangles when trying to ball to work with
try to wind the new yarn on a paper towel roller and as you use it that will unwind easier.. you can put the roll on a horizontal mount that will allow it to feed out untangled..your monut could be attatched to say, an end table..it could be a short peice of broomhandle..
Feb 02, 2014 | Bernat Boa Yarn
My pull cord is stuck. It will only pull so far and it stops
Remove the top cover to your engine, along with any attachments. Your cord is in the top of this cover. You will be able to see where the problem is when you pull the cord.If you find that the cord has tangled somehow, you will need to untangle the cord. Be careful not to damage the cor in the untangling process. GOOD LUCK.
Sep 24, 2011 | Garden
Weed eater line won't advance.
I know it may sound stupid but on the spool their should be arrows that direct you which way to wind the line if you just added line. Some think one goes one way and the other goes the opposite but they both go around the spool in the same way and do not go in the knotches at the top just out the holes. Make sure the spring did not fall out of spool if their is one in that model and while it is running just tap the bottom of the spool on the ground. If that does not work more than likely when you pushed the line back up into the shaft to screw on the knob the line is pinched between the two holding slots. Turn the trimmer upside down (while off) and push knob in and pull line on both sides to advance line. If line does not come out your line is wound wrong or twisted inside spool and must be untangled and reattached. Both lines run the same direction on spool!
Aug 25, 2010 | Homelite Mighty Lite Lawn Trimmer
How do i untangle the pull cord on my leaf blower, it is jammed inside (210MPH/450CFM Craftsman)
just tack the recoil off they are usually easy to remove do to the nature of the part then you should be able to unwind and untangle. in the future dont let go of the cord until it is wound back up that will elininate the back lash and tangling
Oct 31, 2009 | Craftsman 4 Cycle Blower/Vac
SHIMANO AMERICAN CORPORATION Sienna 1000 Front Drag Spinning Reel Logo
110 people viewed this question
Top SHIMANO AMERICAN CORPORATION Fishing Experts
ray gallant
MODERATOR Canada
MODERATOR Canada
Tom Chichester
Are you a SHIMANO AMERICAN CORPORATION Fishing Expert? Answer questions, earn points and help others
