Question about Compaq Easy Access Smartcard Keyboard
Xtream card memory 256 MB
CARD MEMORY HAS A VIRUS
Posted by magdy-shahin on
Anonymous
    Problem Solver:
  • 11 Answers
I have never heard of this scenario before and it is highly doubtfull but if you have a virus.... But if you do...
Connect you camera to your PC (via USB or cradle)... This should add a new external drive... Scan this drive with your anti-virus checker and remove the virus...
If you have a card reader, remove the memory card and insert it into the card reader and repeat the above steps...
Posted on Nov 10, 2007
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
Should you use an 8gb sd memory card in a panasonic lumix dmc-fx3 camera ?
The manual lists the following SD cards compatible:
4 GB SDHC Memory Card
2 GB SD Memory Card
1 GB SD Memory Card
512 MB SD Memory Card
256 MB SD Memory Card
128 MB SD Memory Card
64 MB SD Memory Card
An 8GB card may or may not work. If you try it, make sure it is an SDHC card. (Note: HC=High Capacity)
Thanks for using Fixya.
Apr 27, 2010 | Panasonic Lumix DMC-FX3 Digital Camera
I want remove write protection from my kingston usb flash memory 8g
check on that flsh memory you find 1 right protection lock unlock it then check .
Also some times this error comes because of virus so scan it with updated antivirus.
Jul 28, 2009 | Kingston flash memory card - 256 MB -...
Memory card eror
go back to who that formated your memory card and tell him whats wrong he will take care of it from there its not suppose to charge anything
Jun 23, 2009 | Kingston flash memory card - 256 MB -...
How to remove the write-protecteion from my memory card?
Click > Start > Run > type "CMD" Then
Type "CHKDSK" and type the letter of your Pendrive and "/F".
chkdsk Q: /F > press Enter
another example:
chkdsk D: /f
chkdsk E: /f
D or E is the letter or your pendrive.
May 04, 2009 | Kingston flash memory card - 256 MB -...
What kind of memory SD card would work for Panasonic DVD Recorder DMR-ES46V? I was hoping to put in a 8 gig memory card but those are all SDHC. Will those cards work in this unit?
This info is straight from the panasonic website. The owners manual and more info for the unit can be found here.
Hope his helps!
Suitable SD Memory Cards
8 MB, 16 MB, 32 MB, 64 MB, 128 MB,
256 MB, 512 MB, 1 GB, 2 GB (Maximum)
Mar 16, 2009 | Panasonic DMR-ES46VS DVD Recorder/VCR
TROUBLE!
Hi im josh in cebu phils. may i help you? friend if that happens where your card is empty and it says full. Friend that is a symptom of a virus attacked. try to check or scan your memory disk. Most of the virus  namely  "trojan" causes this kind of problem. and if you don't have any important files inside the memory card then try to format to remove all the viruses that are hiding in your memory card. good luck friend!
Feb 24, 2009 | Kingston flash memory card - 256 MB -...
Nikon Coolpix 4600: Problem: It won't take any photos, it reads: THIS CARD CANNOT BE USED. The card is 128 MB. I purchased a new card: 2GB but it won't work also. My manual says to clean the contacts...
1) Have you formatted the cards?
2) Try the cards in the card reader in your computer to see if they can be read.
3) Try the "switch off camera - remove and replace battery - switch on camera" trick with the original 128 Mb card in place. This will reset the camera's memory.
4) Note the type of card is important - not all cards can be used in a camera (especially some of the latest bigger ones) - check the type of cards supported by your camera.
I found this at the Nikon USA site (note that the 2 GB card is not listed - as said "Cards are not all the same" and use different drivers to operate them):
Question Which Secure Digital Cards are approved for use in the Coolpix 4600/5600? trnsp.gif Answer The Nikon Quality Department has tested the following cards and approved their use in the Coolpix 4600/5600:
SD memory cards:
SanDisk 16 MB, 32 MB, 64 MB, 128 MB, 256 MB, 256 MB*, 512 MB, 512MB*, 1 GB
Panasonic 16 MB, 32 MB, 64 MB, 128 MB, 256 MB*, 512 MB*,1 GB
Toshiba 16 MB, 32 MB, 64 MB, 128 MB, 128 MB*, 256 MB, 256 MB*, 512 MB
*High speed type of 10 MB/s or over
Other brands and capacities of cards may work, but Nikon cannot guarantee their operation. Check with the manufacturer of the third-
party card for compatibility information. Nikon recommends keeping one of the approved cards available for troubleshooting.
May 07, 2008 | Nikon Coolpix 4600 Digital Camera
It is slow with memory card provided with mobile 256mb.
hi ,
u can go for max512 mb..dont go 1 gb as this will hamper the speed of ur mobile..& if u switch to 512 mb..do try to keep all the stuff in memory card rather than sim memory..transfer mostly all the things from phone memory to mem card.This will sort the speed problem of ur mobile
Thanks
Gizmo1
Oct 19, 2007 | Sony Ericsson W300 Cellular Phone
Compaq Easy Access Smartcard Keyboard Logo
54 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Lee Hodgson
Lee Hodgson
Toby Lee
Toby Lee
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
