Question about Building Materials
What is the weight of a cylinder with outside radius=1.6meters. thickness .100 height 5 meters
Philip Hughes
    Habit-Forming:
  • 80 Answers
What material is it made of? Is the thickness 10cm? Does it have a top and bottom?
Posted on Sep 02, 2016
What is the volume in liters of a water tank with ....... radius 2 feet 6 inches height 5 feet 2 inches
Assuming you are correct that the radius is 2' 6" and not the diameter.
Convert the inches to centimetres
1" = 2.54 Cms
Radius = 2' 6" = 30" X 2.54 = 76.2 Cms
Height = 5' 2" = 62" X 2.54 = 157.48 Cms
Volume of cylinder = Pi x radius squared x height
3.142 x 76.2 x 76.2 x 157.48 = 2,873,038.9 cc
Divide by 1000 to find how many litres (interest note 1000cc car engine is 1 litre)
2,873,039 cc / 1000 = 2,873 litres
Nov 08, 2017 | The Office Equipment & Supplies
Honda crv dimensions
HondaCRV is an best Suv car across the world as it the style, good mileage and best in class interior features to beat competition in the auto industry.Here I have mentioned the dimension of Honda CRV 2WD, take a look
1) Length:
4545 mm
2)Width
1820 mm
3)Height
1685 mm
4)Wheelbase
2620 mm
5)Front Track
1565 mm
6)Rear Track
1565 mm
7)Ground Clearance
170 mm
8)Kerb Weight
1475 kg
9)Gross Vehicle Weight
1830 kg
10)Boot Space
490 litres
11)Fuel Tank Capacity
58 litres
12)Minimum Turning Radius
5.5 meter
Check out the Test Drive video of Honda CRV.
Oct 11, 2017 | Honda Cars & Trucks
Find the volume of a cylinder the radius is 8cm the height is 6cm what is the volume
Volume of right cylinder is
V=(Area of base)*height.
If cylinder is circular Area of base =PI*radius^2=Pi*r^2
Volume is V=Pi*(8^2)*6 cm^2
Finish the calculation.
Jun 28, 2014 | Office Equipment & Supplies
Find the volume of a cylinder with the radius 8cm and the height 6cm. Use 3,14 for round answer to the nearest tenth
Jun 28, 2014 | Casio MS-80TE Calculator
Volume of a cylinder formula
Volume of a right circular cylinder of radius r and height h is
V=PI*(r^2)*h
Figure out which is the radius and which is the height, then plug in the formula above. Result is in cm^3
Jun 26, 2014 | Office Equipment & Supplies
Calculatevolume of a water cylinder 40cm Radius with a 1m height
About 503 liters or 0.503 cubic meters.
If this is homework, be sure to show your work.
Dec 08, 2013 | Texas Instruments TI-83 Plus Calculator
How to calculate the weihgt of circular cones
(1/3) x pi x radius2 x height x density = pounds
where ::
radius = radius of base in inches
density = pounds per cubic inch
height = height in inches
(or you could use feet, meters, cm, mm for radius & height and use kg for density or wahtever units you wish as long as the units are consistent)
Charlie
Feb 22, 2011 | American Standard Plumbing
If a lead pipe 1/4in.thick has an inner diameter of 1/2in.,find the number of cubic inches of lead in a pipe 10ft.long
A pipe can be seen as two cylinders, one of "air" sitting inside the other, in this case lead.
To get the volume of a pipe you thus subtract the volume of the "air" cylinder from that of the lead cylinder.
Volume of a cylinder = area of circular cross section (or pi times square of the radius) times the height (or length) => ? * r2 * h
Volume of a pipe = Volume of cylinder 1 (outer diameter) - volume of cylinder 2 (inner diameter).
In this case; Volume of outer cylinder => inner diameter 1/2" (0.5") + pipe thickness 1/4" (0.25") = 3/4" (0.75") divided by 2 to get radius = 0.375".
3.14 (?) * 0.375 * 0.375 * 120(10 feet) = 53.01438 in3
Volume of inner cylinder => inner diameter 1/2" (0.5") divided by 2 to get radius = 0.25".
3.14 (?) * 0.25 * 0.25 * 120(10 feet) = 23.56194 in3
Volume of lead in this pipe = 53.01438 - 23.56194 = 29.45244 in3
Hope this helps ;)
Jan 27, 2011 | Computers & Internet
Building Materials Logo
192 people viewed this question
Top Building Materials Experts
Tom Chichester
Lawrence Oravetz
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
