LG 55LE5400 TV Logo
A
Anonymous Posted on Aug 28, 2014
Frozen screen,has sound,remote does not work,turns off and on
1 Related Answer
Anonymous
  • 54 Answers
  • Posted on Sep 26, 2009
SOURCE: frozen screen , has sound,remote does not work, turns off and on
The 42PC1DV has a freeze screen function. Looks like you may have accidently switched it on .....check your tv manual on how to switch it off.
1helpful
My remote is frozen on 'watch tv'' . device button, help button will not work. off button not working, initial screen to turn on devices does not appear. remote is fully charged
Hi, try updating the firmware in safe mode.
1. Remove the battery, press and hold the 'Off' button, and re-insert the battery. The screen will say 'safe mode'.
2. Connect to the software and click 'Downloads' at the top of the screen.
3. Click 'Firmware'.
4. Update the remote
1helpful
Screen is frozen on with no picture and no sound. Does not respond to either remote control or manual controls. The tv did work and then after a few minutes went frozen.
You need to move further south if it is frozen. It's cold up north :-)
If you've pulled the power from this tv (power cycled it) and it still has this problem ... frozen with no picture and no sound. How a screen can be frozen with no picture, I'm not sure. But it sounds like you are going to be on your way to the repair shop. Or to buy a new tv.
If I couldn't see and couldn't hear, how would I know you were even here?
Frozen screen , has sound,remote does not work, turns off and on
Television displays in blue , only checked all
For your remote problem, mine has stopped working a couple of times and here is what Sharp had me do: Take the batteries out of the compartment. Next press and hold down the power button on the remote for a count of 30 seconds. Return batteries and the RC should be reset. As for the other problem, I had a similar thing happen tonight, hence I am on this site looking for help. My remote quite working, so I did the above, to no avail. I noticed the channel number box was frozen on the screen. I could not turn the TV off manually and had to unplug from AC. I plugged it back in and got sound but no picture, just that bluish dark screen. TV would not turn off. Then I got nothing, no sound, no pic. I left the TV unplugged for several minutes, 5 or so, plugged it in and it did work and is working now, RC too. You might try unplugging it for an extended time.
Picture is frozen but the sound is working.
I'll think that your TV has the child-lock (parental control) switch on.
You can change that in the menu.
I'll hope this works out for you.
Kind regards,
Gerard
Dvd frozen
any storms around? sounds like a power spike tanked it
2helpful
Frozen Pronto
Hi
Thankyou for the offer, but I finally fixed it.
I searched high and low on the Internet and finally found a document that led me to believe it was WIFI problem. I reset (switched off and on) the WIFI receiver, and removed/replaced the battery in the remote control and hey presto. it worked and is still working.
Daryl
10helpful
Samsung LE26R Digital Frozen
Solution that worked for me:
Beware: Although the process should be safe, it technically voids your warranty.
Enter the service menu:
1 - turn of tv with remote
2 - press and release in the following order on the remote: Info, Menu, Mute. Make sure remote is pointing at the tv
3 - turn on the tv from the remote
4 - you will see the service menu. using the down arrow on the remote select the Reset option. Using the right arrow button at this point will do a hard reset.
5 - Wait a few seconds, turn TV on
6 - you will have to rescan analogue and digital channel but it should be working now.
3helpful
Cannot change channels in digital mode
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
